Hello Z-Wave.Me Support Team,
I am using a Z-Station by Z-Wave.Me with a Raspberry Pi 5, running Z-Way Server version 4.1.4.
Z-Wave works perfectly, but Zigbee cannot be used:
In Apps → Instances, only “Zigbee Network Access” is present.
In the App Store (Cloud tab), there are no additional Zigbee apps / no Zigbee UI available.
The menu item Devices → Zigbee results in an error
(“The page you’re looking for could not be found”, route #/zigbee/manage).
A Zigbee port is configured (/dev/ttyUSB1), and the hardware is detected.
Zigbee devices cannot be paired.
For comparison, the same Zigbee devices can be paired without issues using deCONZ.
From my understanding, this means that a Zigbee backend/API is present, but no local Zigbee UI or Zigbee manager is available to create a Zigbee network, set the channel, or manage devices.
I would appreciate clarification on the following points:
1. Is Zigbee with Z-Station officially supported in Z-Way 4.x?
2. If yes:
– Which Z-Way components / apps are required?
– How can the Zigbee UI (Devices → Zigbee) be enabled correctly?
3. If no:
– Is it planned to provide the Zigbee UI again, or is Zigbee intended to be headless / API-only?
Thank you in advance for your support.
Best regards,
