Hi @PoltoS,
Right now, my setup is quiet simple:
rPI3 with razberry 7pro using ser2net (to send serial port over network)
VM using ubuntu to run z-way-server 4.1.4
Running fine since a couple of years without any issue!
My plan right now it's to move both of them into a new rPI5 using docker (as z-way-server can't be installed on trixie)
What's the plan to backup/restore my config properly ?
I try a couple of time using the git repo from trident and also the one from z-wave.. i'm able to see the razberry HAT inside docker with the default/startup config BUT everytime I restore the config, everything is broken and having the error that z-way-server can't read/write the config.
Any idea/clue ?
