Did somebody try to use node.js modules in a userModule? Is this generally possible?
Would it be sufficient to use require.js to get the node.js modules loaded? Any hints?
using node.js modules in userModule
Re: using node.js modules in userModule
I'd like to know this too...
Depends on a module. Those with native code won't work, but pure js modules might be run (probably with some adoption).
