Help using java to access API
snesbittsea
Post by snesbittsea »
I'm looking for a java code example that demonstrates logging in and then accessing the api.
Currently I'm sending an HTTP post along with an HttpContext, but I'm not getting back the expected cookie.
Thanks in advance,
-steve
DomotikQuebec
Contact:
Re: Help using java to access API
Post by DomotikQuebec »
To help you, some code you are using may guide us to what you lack.
Mario Gravel
Domotik Quebec
snesbittsea
I finally got it to work by adding a string representation of a json object to the entity.
Here's my initial code. Based on the API documentation section 3.4.1 I thought this should work. In this case, however, no cookie is returned.(Note that this is written in groovy using the Apache HttpClient library).
def uri = new URIBuilder()
        .setScheme("http")
        .setHost('xxx.xxx.xxx.xxx:8083')
        .setPath('/ZAutomation/api/v1/login')
        .build()
HttpClient client = HttpClientBuilder.create().build();
CookieStore cookies = new BasicCookieStore();
HttpPost request = new HttpPost(uri);
HttpContext httpContext = new BasicHttpContext();
httpContext.setAttribute(HttpClientContext.COOKIE_STORE, cookies);
List <NameValuePair> paramList = new ArrayList <NameValuePair>();
paramList.add(new BasicNameValuePair("login", 'xxxx'));
paramList.add(new BasicNameValuePair("password", 'xxxx'));
request.setEntity(new UrlEncodedFormEntity(paramList));
response = client.execute(request, httpContext);
Here's the code that finally worked, The difference is that rather than passing in login parameters as key/value pairs, I pass them in in the entity object as a stringified version of a json object.
    .setScheme("http")
    .build()
String json = '{"form":"true", "login":"xxx","password":"xxx"}';
StringEntity entity = new StringEntity(json)
HttpPost loginRequest = new HttpPost(uri);
loginRequest.setEntity(entity)
loginRequest.setHeader("Accept", "application/json");
loginRequest.setHeader("Content-type", "application/json");
response = client.execute(loginRequest, httpContext);
DomotikQuebec
Contact:
The problem seems to be the URLEncoding... It is use when you do a GET Request and you want your JSON in the "URL"
When posting, don't ! ;-) It will screw your json.
for example, a space will become %20
Mario Gravel
Domotik Quebec
