z-way-server does not start in Stretch
coolbloke1324
Re: z-way-server does not start in Stretch
Post by coolbloke1324 »
Hey folks,
Not ideal, but you can install libssl1.0.0 on stretch by running:
wget http://ftp.de.debian.org/debian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u7_amd64.deb
sudo apt install ./libssl1.0.0_1.0.1t-1+deb8u7_amd64.deb
After this, I was able to run z-way-server on stretch.
TomB9
Post by TomB9 »
aLiEnHeAd
Post by aLiEnHeAd »
Mir88d wrote:
28 Apr 2018 15:09
Maybe someone knows another z-wave server which is compatible with z-wave.me UZB stick and Raspbian Stretch?
This solution did not work for you?
https://forum.z-wave.me/viewtopic.php?f=3417&t=26138
TomB9
Post by TomB9 »
epoitras
Post by epoitras »
It's been a year now this issue is open. It should really be time to fix it and support stretch.
Please try this:
VER="2.3.8-rc6" && cd /tmp/ && rm -f *.deb && wget https://storage.z-wave.me/z-way-server/z-way-${VER}_armhf.deb && wget https://storage.z-wave.me/z-way-server/webif-1.1_armhf.deb && wget https://storage.z-wave.me/z-way-server/zbw-1.1_all.deb && sudo dpkg -i *.deb
Answer:
Y on /etc/init.d/z-way-server
Y on /etc/logrotate.d/z-way-server
N on /etc/zbw/userid
N on /etc/zbw/passwd
N on /etc/zbw/local_port
skavan
Post by skavan »
port 1883 doesn't activate.
presumably because of some failure pre-launch.
I have tried your suggestions above (VER= bla bla bla).
This is quite ridiculous. Stretch has been the default OS for the rpi for ages. I bought the razberry to use with zway...and it is nuts that I have zero functionality.
Please give me a step by step on how to get this working on a Pi 3 with Stretch. The Razberry is attached to dev/ttyS0.
stkar
Post by stkar »
Hi
Eureka!
Downloaded
2018-06-27
Stretch 4.14
Downloaded
RaZBerry 2.3.7
Thanks for this "mtylerb" you are a God!!!
https://www.raspberrypi.org/forums/view ... p?t=215389
Now with changed to "9".
$ cd \tmp
$ wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
$ sudo dpkg -x libssl1.0.0_1.0.1t-1+deb8u9_armhf.deb .
$ sudo mv usr/lib/arm-linux-gnueabihf/lib* /opt/z-way-server/libs/
Maybe last sudo mv with some permission change ... do not remember exactly.
Wow, everything works (22 aug)!
