The following changes are made in this version:
- Update of the Z-Way version from 4.1.0 to 4.1.3.
- Fixed a problem with remote access, if you have ID 197811, it will be replaced with a new one. Also, at the first launch, a new unique ID will be obtained
- An additional port input field has been added, this field is required if you are going to use an additional adapter in Z-Way, for example ZigBee or EnOcean or Z-Station.
- The image size has been reduced, now it is not based on the virtual environment of Raspberry Pi from balena, now we use the debian image from home assistant, everything now works in the hassio environment
- We also switched to the s6-overlay launch system, for better compatibility with the Home Assistant
- Removed useless ports 1883 and 8883, which interfered with the mqtt broker
- Added a field with a choice of logging level, disabled by default so as not to torment the microSD memory card, if you need logs, just specify the value 0
If you want to participate in testing, install a second DEV repository for yourself, you can make a backup copy from the last addon and restore it. Before launching the test version of the addon, do not forget to disable the main one. Here is a link to the DEV repository.
https://github.com/msazanov/ha-z-wave-me-addon
