Error Rule
Posted: 07 Dec 2012 21:18
by eligv
"Rule triggering: Forbidden, Rule with id = 7 not found"
Are you sure you have pressed
Are you sure you have pressed Save button on the Rules tab before triggering rule action?
yes. routines all give me the
by eligv
yes. routines all give me the same error triggered by.
Fixed!
Fixed!
It was due to empty titles of your rules, scenes or climates (all gave this problem - in your case probably only one of them was empty). We have fixed the code to handle it correctly. Please have a try.
