Page 1 of 2
Failed to perform handshake: (null)
Posted: 03 Feb 2013 12:59
by kopite
I have been getting this error since this morning
Can anyone explain what it means?
I have tried power cycling the RPI but nothing
I have just noticed that when
by kopite
I have just noticed that when i try and re download the certificates the zip contains
ff
pyzw_stdout.log
ssl_py.old
What would be causing this?
We are fixing this problem.
We are fixing this problem. Was on server side.
Thanks PoltoS, looks like it
by kopite
Thanks PoltoS, looks like it is connecting now but devices do not update statuses or respond to outputs
Everything was restarted, so
Everything was restarted, so should work. please check
PoltoS, no good mate, still
by kopite
PoltoS, no good mate, still not updating....should i redownload my certificates?
Which device does not update
Which device does not update it's status? Should it? Are you sure the device is associated with Z-Cloud node id?
kopite - did you get your
by homeauto@mfhome.co.uk
kopite - did you get your certificates? those files you saw ff, pzyw etc were errors I think. The cert files usually look like filename(s).cert
Guys
by kopite
Guys
It started updating again last night and has been running fine since then.
Homeauto i did not install the certs once i noticed they were the wrong ones.
Thanks for the support
same problem today
by Frédéric
I'm trying to connect for the first time whitout success. I followed the right way but have the message "Failed to perform handshake: (null)". I noticed that if you download certs today, they are not the good one (pyzw_stdout.log,...). I did not download these and got the good one from a previous download.
Thanks for your support
