Quick question regarding Raspberry SD Card image
Shazard
Post by Shazard »
Would it work.
Suppose I buy fresh new SD Card with 8GB and install default Raspberry Rasbian Image whichever is provided by Raspberry community.
Then I install Z-Wave.Me as it is here on site.
Configure SSH access to the raspberry.
And... start cloning this SD Card... will each clone work on different Raspberry Pies?
Re: Quick question regarding Raspberry SD Card image
yes, except for remote access - they will all pretend to have same Z-Box ID.
I would suggest you to just take the full image from our website. It has remote access init code inside.
We will also release new image based on latest Raspbian soon
Shazard
Post by Shazard »
Mmm... what is Z-Box ID? Is it somehow generated when installiing software and cloning will not do so?
yes, it is generated on first boot and clonning will copy same ID.
It is for remote access via find.z-wave.me
Shazard
Post by Shazard »
Hmm I have missed something big? When did this appeared? And how do I use it and why should I use it? Is Doc updated somewhere?
This is a separate service. It is installed with RaZberry and comes on port 8084. It allows you to configure IP, restart Z-Way, update Z-Way and have remote access thru find.z-wave.me
n0ahg
Post by n0ahg »
Is there a way to keep the same Z-Box ID for find.z-wave.me if you have done a clean install?
yes. keep few files from old config - in /etc/zbw
n0ahg
Post by n0ahg »
Any way to regenerate the files for my old one as I liked having the low number? :-)
I'll back up the files for the one I have now though, thank you for the information.
If you deleted you private key - no! Authentication is based on priv/pub key pair. We store only public, your box stores private
