Freeze after several minutes.
cedru
Post by cedru »
I just look for a little help. I have a rapberry B and of course a Razberry module. I use the latest version of Raspbian and Razberry drivers are up to date.
I contaste loss of Razberry service operation for several minutes after power up.
The reboot of rapsberry freeze after a warm reboot. (The raspberry plant never in one place for the reboot) and any of the following. J
If Raspbeery and Razberry are hot. The only way to start properly and to remove the Razberry on the card raspberry pi.
The Razberry unit working again a few minutes after a break of an hour or two.
thank you.
Cedric
fableman
Re: Freeze after several minutes.
Post by fableman »
Remember the Raspberry 2 need more power then the old versions.
I use 2.1A power source for the Raspberry 2.
Not sure if that is your problem but I would check that as first thing.
pofs
Post by pofs »
Is Raspberry still operating after service stopped? Can you still access SSH or other services?
Also does the problem persists if running Raspberry Pi without RaZberry card?
cedru
Post by cedru »
I use 2A power source for the Raspberry 2. But, I have already tried several differents power supplies
Is Raspberry still operating after service stopped? Yes
Can you still access SSH or other services? Yes, but no after hot reboot ( freezing during boot)
Also does the problem persists if running Raspberry Pi without RaZberry card? No
fableman
Post by fableman »
If Power supply ok try with a different brand of SD card.
Some SD card brands and with class 10 have problems with raspberry PI, try get a class 6 card. It's abit slower but you will see no difference for z-wave things.
I hade some problems before with SD cards myself, but changed to class 6 card on critical things and now I never have problems, even that my raspberry is outside in extremt temperatures. -13 to +30 :)
Or simply you got a bad razberry unit. (I orders 3 of them and all of them were ok)
cedru
Post by cedru »
I also try this, but I do not think this has piste.Without Razberry, uptime is several days without problems.
I buy the razberry it a few months ago. I already had the same problem at the start. I did not investigate for lack of time.
Started again, I updated the Razberry drivers and rasbian . But the problem persists.
pofs
Post by pofs »
Even if the RaZberry board is defective, I can hardly believe serial port can prevent Raspberry from rebooting. Have you looked into z-way-server.log in case there's something interesting there? Is it only expert UI not working, or HA UI too?
cedru
Post by cedru »
I found the problem. The card don't l'ike my second Network adapter with ip in the same Network.
