It arose an unexpected problem: an association between a Multisensor and a PowerSwitch does not work as it worked properly until a few days ago.
Do we try together to figure out what is wrong?
Hereafter in detail is the analysis of the problem.
I associated to the Fibaro Routing Binary SENSOR_2 a Fibaro Binary Power Switch_3 (in particular the component 3.1), connected to a desk lamp. Until a few days ago the lamp was lit for 30 sec. if anyone was detected bu the sensor. Now this does not happen anymore, even if I can turn on the lamp by HA UI clicking the On button of the switch.
That's how it is configured now the association between my Multisensor and PowerSwitch.
Consider that I have tried unsuccessfully to fix the problem by re-inserting the two devices and then re-creating the association (Expert UI> Configuration for Routing Binary SENSOR_2).
What can I do?
Claudio
