I cannot access devices via API like:
https://ip-of-zway:8083/ZAutomation/api ... yDevice_95
I get error:
{"data":null,"code":404,"message":"404 Not Found","error":"Device DummyDevice_95 doesn't exist"}
Happens in the latest rc's
Device API no longer available
Re: Device API no longer available
I think it was removed. now it is just "expert" and "smarthome".
Does it also fail if you use http instead of https?Quax1507 wrote: https://ip-of-zway:8083/ZAutomation/api ... yDevice_95
It works with http
Next issue!
With older RC's I used Nginx as reverse proxy and apps for geolocation (on iPhone).
App can do HTTP GET and POST with HTTP basic authentication.
But now app would have to log in to UI for changing values.
Can I configure Z-Way sever to use HTTP basic authentication instead?
No ;(
Basic Auth is very unflexible
