Hi all.
just got my UZB yesterday (US version) and trying to configure it to work with the frequency script to 915MHZ
right now i am using homeseer on a raspberry pi and when i try to search devices i see the led blinking.
now i can the script to change it and it did tell me it changed the frequency but i have 2 questions:
1) do i need to run this script each time i boot the pi?
2) how do i know that it actually changed anything since i still cant find any devices on the network
and bonus question: right now i have zipato dual module, will it work with UZB or is it a closed module?
thanks
Frequency Script
Re: Frequency Script
no one ever used this script to change the frequency?
i have no idea if i am doing it ok and as of now, homeseer doesnt find any nodes on the network.
i would like to know if this is actually doing anything before i order more ( i need a large amount)
Are the devices you try to control also in the 915 MHz (Israel/Palestina) region range? If not I don't think your change makes sense.
Contact the manufaturer directly info@Zwave.me and also tell them how many you may ultimately need
yes they are
they are from zipato on the 916.08MHZ. that is the approved frequency in israel.
do you know how i set it on the linux machine?
is there a way to validate i am on the write frequency?
