Yale KeyFree Inclusion Issues
Posted: 29 Nov 2015 20:11
by coolbloke1324
I've purchased and had professionally installed a Yale KeyFree lock: http://www.yale.co.uk/en/yale/couk/prod ... mart-lock/
It includes a z-wave module. When I switch the UZB dongle into inclusion mode and then tell the door lock to go into inclusion mode, ZWay Expert UI tells me the device has been included, but when I look at the details of the interview none of the functions of the lock are present.
All I get after interview is:
0 Basic
0 ManufacturerSpecific
0 Version
I also note that the functions (basic, manufacturer specific) say "security": false... but the lock manual says it will ONLY include on a secure z-wave network.
Does anyone know how to solve this one? I'm currently on ZWay Server 2.0.1 (Ubuntu) and my UZB controller firmware is at 5.2:
2014-12-01 5.2 Update firmware from 05.02 to 05.03
2015-11-07 5.2 Update firmware from 05.02 (EU/US/ANZ/RU/IL/MY/IN) to 05.04 (EU/US/ANZ/RU/IL/MY/IN)
2015-11-11 5.2 Update bootloader for 05.02 to 34A9
I also notice that in the Chrome JavaScript console, if I select the Configuration tab for the door lock it errors with:
GET http://192.168.50.25:8083/config/Configuration.xml 404 (Not Found)
So I'm wondering if I'm missing a file with config data about these locks?
Re: Yale KeyFree Inclusion Issues
Posted: 03 Dec 2015 12:40
by coolbloke1324
OK so after upgrading to 2.1.2-rc17 and dealing with the license issues I had, I am now able to add this lock and set locked and unlocked status.
I don't see where to get reporting (audit) of entry or how to change user codes, however that I suspect is about working out what command codes to send, so it's a positive start that I can now include the device :)
Posted: 19 Mar 2016 07:02
by cbe
Were you able to get what you wanted to work ?
I am actually looking into buying one of these Yale deadbolt (https://www.amazon.ca/dp/B005NLKRAO/ref ... 5ZS5&psc=1).
I am wondering however if we can trigger a zway scene from the deadbolt directly (1 code turn on the light and open the shutters for example, another will just turn on the lights and set the temperature...).
Do you know if that kind of thing is possible ?
