A GE/Jasco dimmer I installed a couple of months ago has disappeared from the Razberry z wave network (the node shows as missing, presumed dead).
The switch itself still works fine as a dimmer when you press the switch panels manually.
I used the Expert UI to delete the switch. I then tried to re-include it, but the Razberry couldn't see it. It also couldn't drop it.
I then used the air gap switch to cut power to the switch and presumably reset it. I still couldn't include it.
Does this mean that the switch's Z Wave connection has failed? If not, what other steps can I take to try and re-instate it in the network?
