was someone successful in setting the temperature threshold fir the Aeotec 5 Multisensor?
I also tried setting it through the Json API but without luck:
ZWave.zway/Run/devices[1].instances[0].commandClasses[112].Set(41,123,2)
- 1 is the node id of my Multisensor
112 is the command class number for configuration
42 is the index number for the temperature setpoint
123 is the dummy value I'm trying to set
2 is the data size
