Page 1 of 2
How to configure KR frequency
Posted: 14 Jun 2016 23:58
by esyjun
I do not know which regional model I should buy due to the frequency.
Could you tell me which regional model I can use in Korea and
explain how to configure KR frequency?
(See also :
http://z-wavealliance.org/z-wave-allian ... an-market/ )
The Korean Communications Commission (KCC), in tandem with the nation's regulatory National Radio Research Agency (RRA), has approved three frequency bands suitable for Z-Wave's sub-Gigahertz transmission protocol. The frequencies approved are 919.7 MHz, 921.7 MHz and 923.1 MHz
Re: How to configure KR frequency
Posted: 31 Jul 2016 02:48
You need ANZ variant and change firmware to a special 3 Channels. This once will work with KR, TW and JP regions
Posted: 17 Sep 2016 10:08
by Park
I also try to use the z-wave devices in Korea.
An Austrailian / NZ Version wonder what to do after purchase.
How do I change the firmware?
The working methods or hint to me.
I want to know more detailed way.
Thank you
Posted: 18 Sep 2016 01:08
RaZberry or UZB? For UZB we have special firmware upgrade to enable 3 channels.
Posted: 08 Aug 2017 15:15
by Park
Over time, I was able to get ZMEAUZB and Z-Way upgrades. And again I have a question about this issue.
Is the special firmware update different from changing the frequency in the Z-Way control panel? If so, how can I get the firmware?
I looked around the Z-way and found the 'IP: 8083 / expert / # / uzb' page. I have updated the boot loader and firmware.
And now the firmware update page will display the message 'Your stick uses the latest firmware'. (Probably a 5.26 version?)
But now the 'Start Inclusion button' does not work anymore.
I get this message. 'Unable to update data. Controller.AddNodeToNetwork (1) '
Did I ever do something wrong ...?
Posted: 09 Aug 2017 20:35
Do you have a license loaded?
Posted: 09 Aug 2017 20:36
And KR requires special firmware. Do you need KR frequency?
Posted: 10 Aug 2017 02:14
by Park
I registered my license through the License Upgrade in the Expert UI.
I also confirmed that Start Inclusion works after registering the license.
But it does not work after firmware update.
And I am trying to connect with Korean z-wave device in Korea, so I need KR frequency.
Thank you.
Posted: 11 Aug 2017 22:37
Korean requires a special three band frequency firmware. So far it is available only for few releases. For 5.26 it was not released yet. We will release it in September. Will try to.push it internally to get it sooner.
Posted: 12 Aug 2017 14:39
by Park
Oh I see. I look forward to September.
