Decipher configuration backup
Posted: 26 Jan 2021 22:06
by alfa001
Is there any way to decipher the config backup?
I need to deactivate the remote ssh secutity issue in the default configuration, since there is no way to do so in the gui. Expanding remote gives blank row.
There is a constant warning on this "feature" when entering config.
Re: Decipher configuration backup
Posted: 27 Jan 2021 02:06
What is the "remote ssh secutity issue" ? Can you attach a screenshot? You can change it in Upgrade -> switch to Remote Access tab in the balck UI and do what you need.
Posted: 31 Jan 2021 12:40
by alfa001
This is the security issue that I would like to disable before starting the service:
--- manual page 23 ---
Right after boot-up, the Z-Way TM controller will connect to the find service announcing its presence. This
is done using a reverse ssh service. The client side of this service is available on the Z-Way TM server and
you can review its work and source code. If you don’t like this service, you can turn it off using the Z-Way
Smart Home Interface . However, be prepared not to have the find service available anymore.
Posted: 01 Feb 2021 04:27
This service does not work on Windows yet. Are you using Windows? If so, you are safe
Posted: 01 Feb 2021 11:56
by alfa001
Using linux, and would like to get rid of the error message and remove the remote exploit before starting the service.
Posted: 02 Feb 2021 09:50
by alfa001
Is it possible to use any of the apis to change/set the configuration? Or list the configuration?
Posted: 03 Feb 2021 04:14
Sure. The easiest way is to change them in the web UI and look in the browser network log for APIs. Or read the doc/sources - they are open on github for the API level
