Node 63:0 CC Security: secure channel not established by primary controller - skipping security
ctrlbreak
Post by ctrlbreak »
I'm not sure what happened here. My Zway RPi didnt come back after a power failure... so I've been rebuilding (on a new SD Card) from backups I took religiously.
For reasons that aren't clear to me, my one "Secure" device didn't return to functionality (A Linear NGD00Z garage door opener).
I've spent the last 7 hours troubleshooting this, and;
- Upgrading the bootloader and FW on the RaZberry...
- Upgrading the installation of Zway
- Excluding / Reincluding the device.
- Manually Resetting the device...
- Drinking and yelling at it.
I'm finally into the z-way server logs and seeing the following:
How is this remedied? I mean, this WAS functioning on the RazBerry itself before... how has this been lost? Is it a key that I could perhaps recover from my failed SD Card? Is that where its stored?
Re: Node 63:0 CC Security: secure channel not established by primary controller - skipping security
The key was stored in confgi/zddx/..../xml
ctrlbreak
Post by ctrlbreak »
Okay. I think I may actually be able to retrieve that file. Is there a way I can simply pluck the needed security information out, or is it safe to just... copy this XML file over, given that I've made other changes while trying to repair my network?
Thanks, btw.
ctrlbreak
Post by ctrlbreak »
I believe I have found my issue. My primary controller *is* NODE 25, as it basically took over from a legacy network many many years ago. For reasons that aren't clear my "secureControllerId" value was pointing at node 0.
https://imgur.com/a/Aeg9Lm8
I stopped z-way-server... updated this to reflect NODE 25, restarted, and it appears I've been able to successfully include my secure device now!
secureControllerId is valid only on own device - check zway.controller.data.nodeId and then check this device
ctrlbreak
Post by ctrlbreak »
I don't quite follow. As I mentioned, NODE 25 *is* my primary controller.
https://imgur.com/a/ExQ8Fon
If it took over the primary role, network keys were not provided to it and it should pretend to be the primary. But shifting controllers is a bit gray zone and it is not well defined how to transfer keys in this situation.
Set this value to 25 and check if it will become better. /JS/Run/zway.devices[25].data.secureControllerId=25
