Increased CPU Load/Temperature with 3.2.0?
Posted: 11 Sep 2021 10:12
by xurg
I noticed that the idle temperature of my RPi based system has gone up by about 4 degrees, and htop constantly lists z-way-server with about 13%. In fairness, I can't tell what z-way-server's load was before the updatre, but still: Is anything know to be causing this? I'm quite certain about the temperature increase and that it coincided with the zway update.
Re: Increased CPU Load/Temperature with 3.2.0?
Posted: 11 Sep 2021 10:26
by xurg
Very interesting observation: I just restarted the server with config.xml:log-level = 1 (I normally use 2 to avoid SD-Card accesses) and the idle load of zway dropped to about 2-3% which is what I seem to recall. Another restart with log-level 2 was ok, too.
Posted: 11 Sep 2021 11:20
May be it is related to some other thing. The most obvious is opened browser: the server load increases on polling by the UI.
Posted: 11 Sep 2021 18:24
by xurg
Good point, but the browser wasn't even open at that time.
Posted: 12 Sep 2021 21:58
You can check the thread eating the most of CPU
