Reorganiztion mass fail after adding S2 capable device
calypso2k
Post by calypso2k »
my network consists of ~45 devices, most of them mains powered and included as "unsecured". I use Z-Way 3.2.0 (3.1.4 has the same problem) with RaZberry firmware 5.39 EU.
When I add S2 capable device, in this case Fibaro FGRGBW-442, the inclusion as S2 Authenticated is successful also interview is 100% complete.
From this point, when I use "Reorganization", when first node will fail to update neighbors, all other nodes fail immediately.
Without S2 device in network, "Reorganization" works as this: if node fails to update neighbors, it is re-queued and another node is updating.
Is it a known problem?
Re: Reorganiztion mass fail after adding S2 capable device
No, it is not. Could you please share the log from the start of Z-Way to reor fail?
calypso2k
Post by calypso2k »
Hi PoltoS,
I would normally do exclude device -> Include device and the problem was persisting but when I did exclude device -> restart Z-Way -> includedevice the problem is solved.
But the real problem is elswhere - please taka a look at https://forum.z-wave.me/viewtopic.php?f=3419&t=34343 I have attached log there. Thank you.
