Z-Way Crash using „My Hubs“
Posted: 02 Aug 2022 02:50
I have installed Z-Way on 3 independent RASPI 4B devices which are using RaZberry hardware. The RASPIs are within one network segment and have static IP/V4 addresses assigned to.
Using the Z-Wave.me iOS app on my iPad it is not possible to use more than one Z-Way system. Once the second and/or third system is added via „My Hubs“ it is not possible to connect to the new added two systems.
- Selecting one of the later added two systems results in an error message „Authorization or channel selection failed“.
- Selection of the first added system always works.
- When using the „Refresh“ function in „My Hubs“ on either of the systems (swiping on one of the systems) Z-Way crashes immediately.
- Removing the Z-Way app and adding the 3 systems in a different sequence shows identical situation with the first and the two remaining systems.
- Connecting to Z-Way via browser instead of app works 100% okay.
- RASPIs and Z-Way are updated to the most actual versions.
- Re-boot of iPAD and RASPI systems do not make any change.
Has anybody ever used the Z-Way iPADOS app with more than one Z-Way system added?
Thanks.
Thanks.
