Dear users,
we are proud to announce that new v2.2.2 is out. Please have a look on the ChangeLog for more info.
In this version we have mostly focused on restoring online Apps, dependency and version managment of apps, stability fixes and usability enhancements in HA. Also we did fixes and enhancements affecting the usability of our user interface. So we've for example redesigned the structure of the ex-/inclusion page and added the possibility to hide or deactivate (Z-Way vDev's only) virtual devices.
Hope you will enjoy this new step forward.
As for us, same procession, we are starting to work on the next version.
v2.2.2 is out
Re: v2.2.2 is out
I did install the update of the firmware, but lost my range. Only close by switches etc are working, things in the other room lost contact. Is this only happening to me? Can I go back to the old firmware?
Re: v2.2.2 is out
Try updating the routing table in the expert ui. I had a similar issue
I can't login after an upgrade. Error loadin data is the message
Never mind, I tracked it down to a missing module dep. sheesh, not very forgiving is it...
Re: v2.2.2 is out
Please give us more information about your issues:
How does it looks after z-way-server restart? Same problem?
Could you please give us a snippet of your logfile?
- Which controller do you have in use? (UZB (should be v5.04)/RaZberry)
- Which FW version did you have installed before?
- Which Browser do you use? - There are some known issues with latest Internet Explorers and Win 10 Edge browser ... Browser gets empty response after login and shows 'unable to load data' - we're still working on that issue
Does Plainsane's answer work?Try updating the routing table in the expert ui.
Downgrading till version v2.1.1 should be possible without bigger problems. Deeper upgrades will touch your storage so it will be better to make a completely fresh installation which means that you are loosing your settings and stuff. Both is not recommended by us and you do it on your own risk.Can I go back to the old firmware?
Does this message occur after you've tried to login?I can't login after an upgrade. Error loadin data is the message
Strange, shouldn't has to do with that. Modules are handled in a special way and couldn't influence that.Never mind, I tracked it down to a missing module dep. sheesh, not very forgiving is it...
Re: v2.2.2 is out
I had a few plugins that depended on base module. This was not installed, my own fault, I just wish the server would load the ui. This was not an issue in 2.2.2-rc5
[2016-04-12 21:04:37.801] [E] [core] result: Error: TypeError: Cannot read property 'meta' of undefined
at AutomationController.<anonymous> (automation/classes/AutomationController.js:737:30)
at Array.forEach (native)
at AutomationController.instantiateModules (automation/classes/AutomationController.js:736:25)
at AutomationController.start (automation/classes/AutomationController.js:198:10)
at automation/main.js:102:16
Re: v2.2.2 is out
Jup this error breaks the startup...
a fix is now available in HA dev branch
You need to overwrite z-way-server/automation/classes/AutomationController.js with that one from the download and also a server restart after overwriting it is necessary.
as alternative you caould only change the lines showing in commit
Otherwise you could downgrade as the following:
- make port 8084 visible via local access: http://localhost:8083/JS/Run/saveObject ... essTimeout', 100000000000);
or with console: echo 100000000000 > automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json
taken from here
- and use the port 8084 to downgrade to v2.2.1 or v2.2.2-rc5
Of course this fix will also be available in next rc.
taken from here
Re: v2.2.2 is out
I hope you didn't drop anything to get that in play, sorry, I had already removed those modules by hand to get the server up. This dude controls my world, it can't be down. But thanx for an official fix that doesn't tank the ui.
Re: v2.2.2 is out
Don't worry. But so I could fix this
Re: v2.2.2 is out
Hi All,
just in case of help,
the only way to fix Login issue with V2.2.2 and new issues appears downgrading to V2.2.1, was to install V2.2.2-rc5.
Overwrite AutomationController.js file didn't work for me.
My Controller is Razberry
I started upgrade from V2.2.1
I use both chrome and mozilla browsers
Downgrading to V2.2.1 caused several new issue (never appeared before)
Messagge appeared when I try to reach login link: once there and pushed "OK" button, blank board appear and every attempt to reach Dashboard Room, Elemts or Config pages generated same popup message
Same problem also after zway restart
Marco
Re: v2.2.2 is out
@marco: do you have also similar problems with modules like plainsane?
I need to figure out why the fix isn't working properly. So could you please give me some more information?
A look at your z-way-server log-file coule be helpful.
It lies on your RPi under /var/log/z-way-server
With
$ tail -f /var/log/z-way-server
you could check what happen during restart in the consolen and if errors occur.
@plainsane: Which modules did you remove to make it work?
With
