Page 2 of 3
Any Update?
Posted: 09 Mar 2013 15:56
by Dave
Could you please tell me when this problem will be sorted out?
We have fixed this. Will come
We have fixed this. Will come in next release (which will contain a lot of fixes).
Update Release
by Dave
Is the next release due soon?
It finished and is in tests.
same problem after adding Fibaro
by McD
I am experiencing the same problems after adding a Fibaro Relay Switch to my installation.
Safari works fine, but Firefox, Chrome will show me the message.
Please update Z-Way (by
Please update Z-Way (by running same command a for installation). This is fixed now (workaround for a bug in JS engine in browsers)
What Have You Done!!!
by Dave
I have just run the update, as you suggested, and I now find the Razberry server will now not even start.
What have you done?
What do you see in the log?
Fresh Install
by Dave
I have no idea what was in the log as I have had to reformat the SD card and install a fresh copy of Rasbian.
With the fresh start I have now got the Razberry server back running.
I think in future I will try new updates on a backup SD card before I over write my working copy.
If it is not running, you
If it is not running, you should see some problem in logs. Do you see the z-way-server process in top/ps?
