Page 3 of 3
Re: How to upgrade RaZberry firmware?
Posted: 09 Mar 2016 05:28
by Plainsane
fableman wrote:After I set the freq to EU (even that it showed EU)
[2015-12-02 11:05:15.350] [D] [zway] SETDATA controller.data.frequency = "EU"
[2015-12-02 11:05:15.350] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): Done
[2015-12-02 11:05:15.350] [D] [zway] Job 0xf2 (Change/Get Z-Wave.Me firmware frequency): success
[2015-12-02 11:05:15.350] [zway] Removing job: Change/Get Z-Wave.Me firmware frequency
Things start to work again!
!!! EU is for my controller and frequency/country I live in, you should set to what ever you should) !!!
suggestion: I think the update routine should check what freq the controller is running,and after the update it should SET the freq on controller automatically.
How did,you,do,this? When I select us as the frequency in the expert ui, it does nothin at all.
Posted: 10 Mar 2016 08:55
by herbert-f
herbert-f wrote:Hi,
I have a problem with upgrade the firmware (bootloader upgrade) at my new razberry (Update bootloader for 01.00 to 538d).
The installed software is v.2.2.1.
When I tried tu upgrade the firmware, it comes "Error handling data" and at the log:
[2016-03-07 21:29:26.490] [core] Failed to download bootloader: Not Found
[2016-03-07 21:29:28.590] [core] Failed to download bootloader: Not Found
Can I download and install the bootloader upgrad manually?
Bye
herbert
Day 3 , we are waiting for an answer and a solution of Z-Wave - Me !
Posted: 11 Mar 2016 04:55
by Plainsane
PoltoS wrote:in fact, a simple chip reboot would be enough. Freq change does it too, so it worked for you
What does this mean? A factory reset?
Posted: 11 Mar 2016 12:29
by pz1
