Enable HomeKit and Auth Code for RaZberry
Re: Enable HomeKit and Auth Code for RaZberry
Thanks for reporting, I'll take a look. Probably there's something changed in latest iOS.
I think I've got it fixed. You may upgrade to 2.0.1-rc1 to test it.
@pofs: Thanks for the fix but unfortunately, it still does not work...
I have tried both 2.0.1-rc1 and 2.0.1-rc4: In both cases I simply get the following error message when entering the PIN from the log output:
I have used this test code:
What code did you use for testing?
HomeKitDemo[6072:741973] Error Domain=HMErrorDomain Code=52 "Failed with OSStatus code -6700 (kUnknownErr)" UserInfo=0x7fafdc9002d0 {NSLocalizedDescription=Failed with OSStatus code -6700 (kUnknownErr)}
git clone https://github.com/KhaosT/HomeKit-Demo.git
Yesterday, while making a Windows version I've found one more stupid issue, which may cause problems on some platforms (probably on RPi too).
I'm developing on OS X, so for a long time it went unnoticed. It is now fixed, and will be included in next release (rc5 or whatever).
As for app I use for testing, I have several of them, including the one you mentioned.
In the current version (v2.0.1-rc5) I get the following error, if I try to enable the HomeKit Gate:
[2014-12-17 20:45:27.992] [core] --- Starting module HomeKit Gate
[2014-12-17 20:45:28.109] [core] Notification: error (core): Can not init module HomeKitGate: ReferenceError: HomeKit is not defined
[2014-12-17 20:45:28.339] [core] ReferenceError: HomeKit is not defined
at HomeKitGate.init (automation/modules/HomeKitGate/index.js:35:19)
at AutomationController.instantiateModule (automation/classes/AutomationController.js:254:22)
at AutomationController.<anonymous> (automation/classes/AutomationController.js:331:22)
at Array.forEach (native)
at AutomationController.loadModule (automation/classes/AutomationController.js:330:86)
at AutomationController.<anonymous> (automation/classes/AutomationController.js:347:73)
at AutomationController.instantiateModules (automation/classes/AutomationController.js:347:46)
at AutomationController.start (automation/classes/AutomationController.js:114:10)
at automation/main.js:294:16
Any ideas?
Thx
Any ideas?
Thx
Not sure, need to check. Is there modhomekit.so under /opt/z-way-server/modules?
Yes, the file modhomekit.so is there.
I am getting the exact same error output from the same github Project and one other HomeKit project, after entering the HomeKit PIN from the razberry pi.CODE: SELECT ALL
I am using Firmware razberry z-way Server 2.0.0 and 2.0.1-rc7
HMErrorDomain refers the following, which isn't really helpful:
HMErrorDomain = 52 HMErrorCodeGenericError
An error occurred for which there is no more specific error code.
Also can´t find any helpful infos for this code:
Homekit Accessory Simulator connections are working perfect with this xcode Project, but connecting to the razberry HW doesn´t.
i don´t know where to start with troubleshooting.
Does anyone know what is causing errors like this?
Would be very nice, if someone can help with this issue.
thank you!
So, i have some more details for the above error.
Looking into the iPhone Simulator System-Log, there are the following log rows, when trying to connect with razberry:
As you can see, Pair Setup failed at Stage 6. Bad Status 0x1 means HomeKit Server failed authenticating the message.
Is there a problem with the HAP in razberry 2.0.1-rc7?
9:49:10.245597 PM [Pairing] ### Pair-setup client M6 bad status: 0x1, -6700/0xFFFFE5D4 kUnknownErr
Dec 28 21:49:10 Davids-iMac.local CoreHAP[1875]: 2014-12-28 09:49:10.246748 PM [Pairing] ### Pair-setup client state 6 failed: -6700/0xFFFFE5D4 kUnknownErr
There's probably an issue with RPi build environment after compiler toolchain update, so it assumes incorrect endianness. We'll check it.vga wrote:Is there a problem with the HAP in razberry 2.0.1-rc7?
