set homeId via echo hex > port
skiv71
Post by skiv71 »
Anyone know the format? for the string?
Neil
pofs
Re: set homeId via echo hex > port
Post by pofs »
There's no such command, at least the official one. Why?
skiv71
Post by skiv71 »
My attempts to restore a backup and hence homeId and node configs is failing, but if I can set the homeId, I can drop the .xml in and carry on as before :)
simonchase
Post by simonchase »
I'm facing the same Problem with z-way-server 2.1.1.
I don't wanna remount all my roller shutter switches ( fibaro fgrm-222 ) and my other zwave-components of the wall and re-include them in a new z-wave-network.
Is there any possibility to set the homeID manually ??
In worst case, i've had to recode all my other stuff in z-way-server-ui?!?!
Please help!
Regards Simonchase
(posted also in the German subforum )
Raspberry PI 2, RazBerry
Z-Way have backup/restore facilities. HAve you tried this?
