How can I fix the problem with the device description for Aon Labs DSD31 Siren wich is available in pepper1.net but creates the following error during indexing.
"Error loading Z-Wave Device Description XML 596-0086-0004-0050-03-03-5c-01-17.xml: list index out of range"
Help to fix pepper1.net device DB problems
Re: Help to fix pepper1.net device DB problems
This means some data in this description is missing. There is XSD schema in the same folder and validation script. Once you understand it, you can report us and we fix it (or directly to P1).
