For What It's Worth:
After a series of internal releases, it seems that a new public releaces candidate rc40 has been published.
Edit: I did encounter some issues at initial use.
Edit2: A couple of hours later there was a different? release with the same number
v2.0.1-RC40 released (Don't waste your time on this release)
Re: v2.0.1-RC40 released
somewhere along the line all the names have disappeared from all my apps.
if logicalrules are invalid then only the name and description will display... can't fix the rule..
Noticed that the names that I edited in the HA UI, also did not persist during upgrade, they reverted to the name assigned by the module.RottenMutt wrote:somewhere along the line all the names have disappeared from all my apps.
As they do not pay attention to this forum whatsoever, I stopped maintaining my systematic error report list
ZWay iPhone app is broken now.
logical rules are broken, can't pick a blank scene.
Has anyone tried with the Android app? I am afraid to upgrade at this point. Last time I lost all my config
Sorry to hear that. I found it really useful to get an idea of progress/regress, since there is no official change log issued for each rc.pz1 wrote: As they do not pay attention to this forum whatsoever, I stopped maintaining my systematic error report list
lists are incomplete if you have lots of devices. probably related to the names disappearing.
why are they working on the UI, they should be working on device support and functionality!!!!
Re: v2.0.1-RC40 released (Don't waste your time on this rele
This release is not worh looking at. Don't waste your time
To help you not waste your time we have removed this RC from public. Guys, we are doing MANY changes last time, please don't install all these RCs. We will invite you to test once we feel safe to share it.
So far these builds are mostly to share code between us and to test these builds on different platforms.
How far back do i need to go to get device/scene "lists" working in Apps? And could you put back up that version.PoltoS wrote:To help you not waste your time we have removed this RC from public. Guys, we are doing MANY changes last time, please don't install all these RCs. We will invite you to test once we feel safe to share it.
Right now some of my logical rules are broken, I attempted to repair the names, and i shouldn't have as they worked and should have just waited out the fix. I can't recreate the rule as i can't select the correct setting as the lists are not complete (subset of what should be available).
