Security interview works?
Posted: 04 Jan 2016 21:10
I've got problems with interview in security mode. Is it suppose to work for v2.1.1? Looking at release notes for 2.2.0 it looks like some fixes has been done for this version? I'm using an Aeon Multisensor 6 (gen 5).
The log looks like:
What should I look for in the logs to get any hints about errors? There are no explicit errors. Interview status is "Device interview stage is not complete".
Job queue says:
The log looks like:
[2016-01-04 18:52:36.664] [I] [zway] Adding job: Add/re-include node to network
[2016-01-04 18:52:36.673] [D] [zway] SENDING (cb 0x07): ( 01 05 00 4A C1 07 76 )
[2016-01-04 18:52:36.675] [D] [zway] RECEIVED ACK
[2016-01-04 18:52:36.684] [D] [zway] RECEIVED: ( 01 07 00 4A 07 01 00 00 B4 )
[2016-01-04 18:52:36.684] [D] [zway] SENT ACK
[2016-01-04 18:52:36.684] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2016-01-04 18:52:36.685] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2016-01-04 18:52:36.685] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2016-01-04 18:52:36.685] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2016-01-04 18:52:38.738] [D] [zway] RECEIVED: ( 01 07 00 4A 07 02 00 00 B7 )
[2016-01-04 18:52:38.739] [D] [zway] SENT ACK
[2016-01-04 18:52:38.740] [I] [zway] Job 0x4a (Add/re-include node to network): Node found: #0
[2016-01-04 18:52:38.740] [D] [zway] SETDATA controller.data.controllerState = 2 (0x00000002)
[2016-01-04 18:52:38.930] [D] [zway] RECEIVED: ( 01 1A 00 4A 07 03 09 13 04 21 01 5E 86 72 59 85 73 71 84 80 30 31 70 98 7A EF 5A C3 )
[2016-01-04 18:52:38.931] [D] [zway] SENT ACK
[2016-01-04 18:52:38.932] [I] [zway] Job 0x4a (Add/re-include node to network): Adding slave: #9
[2016-01-04 18:52:38.932] [D] [zway] SETDATA controller.data.controllerState = 3 (0x00000003)
[2016-01-04 18:52:38.933] [D] [zway] SETDATA controller.data.lastIncludedDevice = 9 (0x00000009)
[2016-01-04 18:52:38.933] [D] [zway] SETDATA devices.9.data = Empty
[2016-01-04 18:52:38.934] [D] [zway] SETDATA devices.9.instances.0.data = Empty
[2016-01-04 18:52:38.934] [D] [zway] SETDATA devices.9.instances.0.data.dynamic = Empty
[2016-01-04 18:52:38.934] [D] [zway] SETDATA devices.9.instances.0.data.dynamic = False
[2016-01-04 18:52:38.935] [D] [zway] SETDATA devices.9.instances.0.data.genericType = Empty
[2016-01-04 18:52:38.935] [D] [zway] SETDATA devices.9.instances.0.data.genericType = 0 (0x00000000)
[2016-01-04 18:52:38.936] [D] [zway] SETDATA devices.9.instances.0.data.specificType = Empty
[2016-01-04 18:52:38.936] [D] [zway] SETDATA devices.9.instances.0.data.specificType = 0 (0x00000000)
[2016-01-04 18:52:38.936] [D] [zway] SETDATA devices.9.data.basicType = Empty
[2016-01-04 18:52:38.937] [D] [zway] SETDATA devices.9.data.genericType = Empty
[2016-01-04 18:52:38.937] [D] [zway] SETDATA devices.9.data.specificType = Empty
[2016-01-04 18:52:38.937] [D] [zway] SETDATA devices.9.data.infoProtocolSpecific = Empty
[2016-01-04 18:52:38.938] [D] [zway] SETDATA devices.9.data.deviceTypeString = Empty
[2016-01-04 18:52:38.938] [D] [zway] SETDATA devices.9.data.isVirtual = Empty
[2016-01-04 18:52:38.939] [D] [zway] SETDATA devices.9.data.isListening = Empty
[2016-01-04 18:52:38.939] [D] [zway] SETDATA devices.9.data.isRouting = Empty
[2016-01-04 18:52:38.939] [D] [zway] SETDATA devices.9.data.isAwake = Empty
[2016-01-04 18:52:38.940] [D] [zway] SETDATA devices.9.data.optional = Empty
[2016-01-04 18:52:38.940] [D] [zway] SETDATA devices.9.data.isFailed = Empty
[2016-01-04 18:52:38.940] [D] [zway] SETDATA devices.9.data.beam = Empty
[2016-01-04 18:52:38.941] [D] [zway] SETDATA devices.9.data.sensor250 = Empty
[2016-01-04 18:52:38.941] [D] [zway] SETDATA devices.9.data.sensor1000 = Empty
[2016-01-04 18:52:38.941] [D] [zway] SETDATA devices.9.data.neighbours = Empty
[2016-01-04 18:52:38.942] [D] [zway] SETDATA devices.9.data.manufacturerId = Empty
[2016-01-04 18:52:38.942] [D] [zway] SETDATA devices.9.data.vendorString = Empty
[2016-01-04 18:52:38.943] [D] [zway] SETDATA devices.9.data.manufacturerProductType = Empty
[2016-01-04 18:52:38.943] [D] [zway] SETDATA devices.9.data.manufacturerProductId = Empty
[2016-01-04 18:52:38.943] [D] [zway] SETDATA devices.9.data.ZWLib = Empty
[2016-01-04 18:52:38.944] [D] [zway] SETDATA devices.9.data.ZWProtocolMajor = Empty
[2016-01-04 18:52:38.944] [D] [zway] SETDATA devices.9.data.ZWProtocolMinor = Empty
[2016-01-04 18:52:38.944] [D] [zway] SETDATA devices.9.data.SDK = Empty
[2016-01-04 18:52:38.945] [D] [zway] SETDATA devices.9.data.applicationMajor = Empty
[2016-01-04 18:52:38.945] [D] [zway] SETDATA devices.9.data.applicationMinor = Empty
[2016-01-04 18:52:38.945] [D] [zway] SETDATA devices.9.data.nodeInfoFrame = Empty
[2016-01-04 18:52:38.946] [D] [zway] SETDATA devices.9.data.ZDDXMLFile = Empty
[2016-01-04 18:52:38.946] [D] [zway] SETDATA devices.9.data.lastSend = Empty
[2016-01-04 18:52:38.946] [D] [zway] SETDATA devices.9.data.lastNonceGet = Empty
[2016-01-04 18:52:38.947] [D] [zway] SETDATA devices.9.data.lastReceived = Empty
[2016-01-04 18:52:38.947] [D] [zway] SETDATA devices.9.data.failureCount = Empty
[2016-01-04 18:52:38.947] [D] [zway] SETDATA devices.9.data.keepAwake = Empty
[2016-01-04 18:52:38.948] [D] [zway] SETDATA devices.9.data.countSuccess = Empty
[2016-01-04 18:52:38.948] [D] [zway] SETDATA devices.9.data.countFailed = Empty
[2016-01-04 18:52:38.949] [D] [zway] SETDATA devices.9.data.queueLength = Empty
[2016-01-04 18:52:38.949] [D] [zway] SETDATA devices.9.data.givenName = Empty
[2016-01-04 18:52:38.949] [D] [zway] SETDATA devices.9.data.lastPacketInfo = Empty
[2016-01-04 18:52:38.950] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = Empty
[2016-01-04 18:52:38.950] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = Empty
[2016-01-04 18:52:38.950] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = Empty
[2016-01-04 18:52:38.951] [D] [zway] SETDATA devices.9.data.basicType = 0 (0x00000000)
[2016-01-04 18:52:38.951] [D] [zway] SETDATA devices.9.data.genericType = 0 (0x00000000)
[2016-01-04 18:52:38.951] [D] [zway] SETDATA devices.9.data.specificType = 0 (0x00000000)
[2016-01-04 18:52:38.952] [D] [zway] SETDATA devices.9.data.infoProtocolSpecific = 0 (0x00000000)
[2016-01-04 18:52:38.952] [D] [zway] SETDATA devices.9.data.deviceTypeString = ""
[2016-01-04 18:52:38.952] [D] [zway] SETDATA devices.9.data.isVirtual = False
[2016-01-04 18:52:38.953] [D] [zway] SETDATA devices.9.data.isListening = True
[2016-01-04 18:52:38.953] [D] [zway] SETDATA devices.9.data.isRouting = False
[2016-01-04 18:52:38.953] [D] [zway] SETDATA devices.9.data.isAwake = False
[2016-01-04 18:52:38.954] [D] [zway] SETDATA devices.9.data.optional = False
[2016-01-04 18:52:38.954] [D] [zway] SETDATA devices.9.data.isFailed = False
[2016-01-04 18:52:38.954] [D] [zway] SETDATA devices.9.data.beam = False
[2016-01-04 18:52:38.955] [D] [zway] SETDATA devices.9.data.sensor250 = False
[2016-01-04 18:52:38.955] [D] [zway] SETDATA devices.9.data.sensor1000 = False
[2016-01-04 18:52:38.955] [D] [zway] SETDATA devices.9.data.neighbours = Empty
[2016-01-04 18:52:38.956] [D] [zway] SETDATA devices.9.data.manufacturerId = 0 (0x00000000)
[2016-01-04 18:52:38.956] [D] [zway] SETDATA devices.9.data.manufacturerProductType = 0 (0x00000000)
[2016-01-04 18:52:38.956] [D] [zway] SETDATA devices.9.data.manufacturerProductId = 0 (0x00000000)
[2016-01-04 18:52:38.957] [D] [zway] SETDATA devices.9.data.applicationMajor = 0 (0x00000000)
[2016-01-04 18:52:38.957] [D] [zway] SETDATA devices.9.data.applicationMinor = 0 (0x00000000)
[2016-01-04 18:52:38.957] [D] [zway] SETDATA devices.9.data.ZWProtocolMajor = 0 (0x00000000)
[2016-01-04 18:52:38.958] [D] [zway] SETDATA devices.9.data.ZWProtocolMinor = 0 (0x00000000)
[2016-01-04 18:52:38.958] [D] [zway] SETDATA devices.9.data.ZWLib = 0 (0x00000000)
[2016-01-04 18:52:38.958] [D] [zway] SETDATA devices.9.data.SDK = ""
[2016-01-04 18:52:38.959] [D] [zway] SETDATA devices.9.data.vendorString = ""
[2016-01-04 18:52:38.959] [D] [zway] SETDATA devices.9.data.nodeInfoFrame = Empty
[2016-01-04 18:52:38.960] [D] [zway] SETDATA devices.9.data.ZDDXMLFile = ""
[2016-01-04 18:52:38.960] [D] [zway] SETDATA devices.9.data.keepAwake = False
[2016-01-04 18:52:38.960] [D] [zway] SETDATA devices.9.data.countSuccess = 0 (0x00000000)
[2016-01-04 18:52:38.961] [D] [zway] SETDATA devices.9.data.countFailed = 0 (0x00000000)
[2016-01-04 18:52:38.961] [D] [zway] SETDATA devices.9.data.queueLength = 0 (0x00000000)
[2016-01-04 18:52:38.961] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2016-01-04 18:52:38.962] [D] [zway] SETDATA devices.9.data.lastSend = 0 (0x00000000)
[2016-01-04 18:52:38.962] [D] [zway] SETDATA devices.9.data.failureCount = 0 (0x00000000)
[2016-01-04 18:52:38.962] [D] [zway] SETDATA devices.9.data.givenName = ""
[2016-01-04 18:52:38.963] [I] [zway] Adding job: Get node protocol information
[2016-01-04 18:52:38.963] [I] [zway] Adding job: Get routing table line
[2016-01-04 18:52:38.963] [I] [zway] Adding job: Check if node is failed
[2016-01-04 18:52:38.964] [I] [zway] Adding job: Get routing table line
[2016-01-04 18:52:38.964] [D] [zway] Job 0x80 (Get routing table line): removing duplicate
[2016-01-04 18:52:38.964] [D] [zway] SETDATA devices.9.data.basicType = 4 (0x00000004)
[2016-01-04 18:52:38.965] [D] [zway] SETDATA devices.9.data.genericType = 33 (0x00000021)
[2016-01-04 18:52:38.965] [D] [zway] SETDATA devices.9.instances.0.data.genericType = 33 (0x00000021)
[2016-01-04 18:52:38.966] [D] [zway] SETDATA devices.9.data.specificType = 1 (0x00000001)
[2016-01-04 18:52:38.966] [D] [zway] SETDATA devices.9.instances.0.data.specificType = 1 (0x00000001)
[2016-01-04 18:52:38.968] [D] [zway] SETDATA devices.9.data.deviceTypeString = "Routing Multilevel Sensor"
[2016-01-04 18:52:38.969] [D] [zway] SETDATA devices.9.data.nodeInfoFrame = byte[16]
[2016-01-04 18:52:38.971] [D] [zway] ( 5E 86 72 59 85 73 71 84 80 30 31 70 98 7A EF 5A )
[2016-01-04 18:52:38.979] [D] [zway] SENDING: ( 01 04 00 62 09 90 )
[2016-01-04 18:52:38.981] [D] [zway] RECEIVED ACK
[2016-01-04 18:52:38.982] [D] [zway] RECEIVED: ( 01 04 01 62 00 98 )
[2016-01-04 18:52:38.982] [D] [zway] SENT ACK
[2016-01-04 18:52:38.983] [D] [zway] SETDATA devices.9.data.isFailed = False
[2016-01-04 18:52:38.983] [I] [zway] Job 0x62 (Check if node is failed): Node 9 is operating
[2016-01-04 18:52:38.984] [D] [zway] Job 0x62 (Check if node is failed): success
[2016-01-04 18:52:38.984] [I] [zway] Removing job: Check if node is failed
[2016-01-04 18:52:39.264] [D] [zway] RECEIVED: ( 01 07 00 4A 07 05 09 00 B9 )
[2016-01-04 18:52:39.265] [D] [zway] SENT ACK
[2016-01-04 18:52:39.265] [D] [zway] SETDATA controller.data.controllerState = 4 (0x00000004)
[2016-01-04 18:52:39.266] [I] [zway] Job 0x4a (Add/re-include node to network): Protocol done
[2016-01-04 18:52:39.266] [I] [zway] Loading Command Classes for device 9
[2016-01-04 18:52:39.267] [I] [zway] Node 9:0 supports CC Basic
[2016-01-04 18:52:39.267] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data = Empty
[2016-01-04 18:52:39.268] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.supported = Empty
[2016-01-04 18:52:39.268] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.supported = True
[2016-01-04 18:52:39.269] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.version = Empty
[2016-01-04 18:52:39.269] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2016-01-04 18:52:39.270] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.security = Empty
[2016-01-04 18:52:39.270] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.security = False
[2016-01-04 18:52:39.270] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.interviewDone = Empty
[2016-01-04 18:52:39.271] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.interviewCounter = Empty
[2016-01-04 18:52:39.271] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.interviewDone = False
[2016-01-04 18:52:39.271] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2016-01-04 18:52:39.272] [D] [zway] SETDATA devices.9.instances.0.commandClasses.32.data.level = Empty
[2016-01-04 18:52:39.272] [I] [zway] Node 9:0 supports CC SensorBinary
[2016-01-04 18:52:39.272] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data = Empty
[2016-01-04 18:52:39.273] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.supported = Empty
[2016-01-04 18:52:39.273] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.supported = True
[2016-01-04 18:52:39.276] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.version = Empty
[2016-01-04 18:52:39.277] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2016-01-04 18:52:39.277] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.security = Empty
[2016-01-04 18:52:39.278] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.security = False
[2016-01-04 18:52:39.278] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.interviewDone = Empty
[2016-01-04 18:52:39.278] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.interviewCounter = Empty
[2016-01-04 18:52:39.279] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.interviewDone = False
[2016-01-04 18:52:39.279] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2016-01-04 18:52:39.280] [D] [zway] SETDATA devices.9.instances.0.commandClasses.48.data.typemask = Empty
[2016-01-04 18:52:39.280] [I] [zway] Node 9:0 supports CC SensorMultilevel
[2016-01-04 18:52:39.281] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data = Empty
[2016-01-04 18:52:39.281] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.supported = Empty
[2016-01-04 18:52:39.281] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.supported = True
[2016-01-04 18:52:39.282] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.version = Empty
[2016-01-04 18:52:39.282] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2016-01-04 18:52:39.282] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.security = Empty
[2016-01-04 18:52:39.283] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.security = False
[2016-01-04 18:52:39.283] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.interviewDone = Empty
[2016-01-04 18:52:39.283] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.interviewCounter = Empty
[2016-01-04 18:52:39.284] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.interviewDone = False
[2016-01-04 18:52:39.284] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2016-01-04 18:52:39.284] [D] [zway] SETDATA devices.9.instances.0.commandClasses.49.data.typemask = Empty
[2016-01-04 18:52:39.285] [I] [zway] Node 9:0 supports CC AssociationGroupInformation
[2016-01-04 18:52:39.285] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data = Empty
[2016-01-04 18:52:39.286] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.supported = Empty
[2016-01-04 18:52:39.286] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.supported = True
[2016-01-04 18:52:39.286] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.version = Empty
[2016-01-04 18:52:39.287] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.version = 1 (0x00000001)
[2016-01-04 18:52:39.287] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.security = Empty
[2016-01-04 18:52:39.287] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.security = False
[2016-01-04 18:52:39.288] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.interviewDone = Empty
[2016-01-04 18:52:39.288] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.interviewCounter = Empty
[2016-01-04 18:52:39.288] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.interviewDone = False
[2016-01-04 18:52:39.289] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.interviewCounter = 10 (0x0000000a)
[2016-01-04 18:52:39.289] [D] [zway] SETDATA devices.9.instances.0.commandClasses.89.data.dynamic = Empty
[2016-01-04 18:52:39.289] [I] [zway] Node 9:0 supports CC ZWavePlusInfo
[2016-01-04 18:52:39.290] [D] [zway] SETDATA devices.9.instances.0.commandClasses.94.data = Empty
[2016-01-04 18:52:39.290] [D] [zway] SETDATA devices.9.instances.0.commandClasses.94.data.supported = Empty
[snip]..
[2016-01-04 18:52:39.502] [I] [zway] Node 9:0 CC Security: sending Network Key Set
[2016-01-04 18:52:39.502] [I] [zway] Adding job: Network Key Set
[2016-01-04 18:52:39.502] [I] [zway] Node 9:0 CC Security: sending Nonce Get
[2016-01-04 18:52:39.503] [D] [zway] SETDATA devices.9.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-04 18:52:39.503] [I] [zway] Adding job: Nonce Get
[2016-01-04 18:52:39.503] [D] [zway] SETDATA devices.9.data.lastNonceGet = 7217517 (0x006e216d)
[2016-01-04 18:52:39.561] [D] [zway] SENDING (cb 0x09): ( 01 09 00 13 09 02 98 40 05 09 3A )
[2016-01-04 18:52:39.563] [D] [zway] RECEIVED ACK
[2016-01-04 18:52:39.567] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-04 18:52:39.567] [D] [zway] SENT ACK
[2016-01-04 18:52:39.567] [D] [zway] Delivered to Z-Wave stack
[2016-01-04 18:52:39.582] [D] [zway] RECEIVED: ( 01 07 00 13 09 00 00 02 E0 )
[2016-01-04 18:52:39.583] [D] [zway] SENT ACK
[2016-01-04 18:52:39.583] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-01-04 18:52:39.584] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2016-01-04 18:52:39.584] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-04 18:52:39.584] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-01-04 18:52:39.585] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2016-01-04 18:52:39.585] [D] [zway] SendData Response with callback 0x09 received: received by recipient
[2016-01-04 18:52:39.585] [D] [zway] SETDATA devices.9.data.lastSend = 7217525 (0x006e2175)
[2016-01-04 18:52:39.586] [D] [zway] Job 0x13 (Nonce Get): success
[2016-01-04 18:52:39.586] [D] [zway] SETDATA devices.9.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-04 18:52:39.586] [I] [zway] Removing job: Nonce Get
[2016-01-04 18:52:39.602] [D] [zway] RECEIVED: ( 01 10 00 04 00 09 0A 98 80 D4 D4 D2 40 7E 67 9B 91 71 )
[2016-01-04 18:52:39.603] [D] [zway] SENT ACK
[2016-01-04 18:52:39.604] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2016-01-04 18:52:39.604] [I] [zway] Node 9:0 CC Security: received Nonce Report
[2016-01-04 18:52:39.604] [D] [zway] SETDATA devices.9.instances.0.commandClasses.152.data.rNonce = **********
[2016-01-04 18:52:39.605] [I] [zway] Removing job: Network Key Set
[2016-01-04 18:52:39.605] [I] [zway] Node 9:0 CC Security: Sending a secure message
[2016-01-04 18:52:39.605] [I] [zway] Node 9:0 CC Security: sending encrypted packet: Network Key Set
[2016-01-04 18:52:39.606] [D] [zway] SETDATA devices.9.instances.0.commandClasses.152.data.toFollow = False
[2016-01-04 18:52:39.606] [D] [zway] SETDATA devices.9.data.lastNonceGet = Empty
[2016-01-04 18:52:39.606] [I] [zway] Adding job: Security, Network Key Set
[2016-01-04 18:52:39.652] [D] [zway] SENDING (cb 0x0a): ( 01 2D 00 13 09 26 98 81 7C F5 FC 31 8E 41 1C 2E 6C B6 ED 8C C4 0A 25 6E BC DF 84 6A 33 3D 7C 5A 7A 31 EC D4 9E AA DA 37 95 47 E4 8C 05 0A CA )
[2016-01-04 18:52:39.657] [D] [zway] RECEIVED ACK
[2016-01-04 18:52:39.662] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-04 18:52:39.662] [D] [zway] SENT ACK
[2016-01-04 18:52:39.662] [I] [zway] Job 0x13 (Security, Network Key Set): Response received - transfered to encapsulated jobs
[2016-01-04 18:52:39.663] [D] [zway] Delivered to Z-Wave stack
[2016-01-04 18:52:39.683] [D] [zway] RECEIVED: ( 01 07 00 13 0A 00 00 02 E3 )
[2016-01-04 18:52:39.683] [D] [zway] SENT ACK
[2016-01-04 18:52:39.684] [I] [zway] Job 0x13 (Security, Network Key Set): Callback received - transfered to encapsulated jobs
[2016-01-04 18:52:39.684] [I] [zway] Job 0x13 (Network Key Set): Delivered
[2016-01-04 18:52:39.684] [D] [zway] SendData Response with callback 0x0a received: received by recipient
[2016-01-04 18:52:39.684] [I] [zway] Job 0x13 (Security, Network Key Set): Delivered
[2016-01-04 18:52:39.685] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2016-01-04 18:52:39.685] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 41 (0x00000029)
[2016-01-04 18:52:39.685] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 21 (0x00000015)
[2016-01-04 18:52:39.685] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2016-01-04 18:52:39.686] [D] [zway] SendData Response with callback 0x0a received: received by recipient
[2016-01-04 18:52:39.686] [D] [zway] SETDATA devices.9.data.lastSend = 7217535 (0x006e217f)
[2016-01-04 18:52:39.686] [D] [zway] Job 0x13 (Security, Network Key Set): success
[2016-01-04 18:52:39.686] [I] [zway] Removing job: Security, Network Key Set
[2016-01-04 18:52:39.713] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 98 40 20 )
[2016-01-04 18:52:39.713] [D] [zway] SENT ACK
[2016-01-04 18:52:39.714] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
Job queue says:
n U W S E D Ack Resp Cbk Timeout NodeId Description Progress Buffer
0 W S - - - 0.20 9 SensorMultilevel V5 Get 9 4 31 4 1b 0 5
0 W S - - - 0.20 9 Wakeup interval set 9 6 84 4 0 1 2c 1 5
0 W S - - - 0.20 9 Wakeup Get 9 2 84 5 5
1 W - - - 0.20 9 Nonce Get Not delivered to recipient 9 2 98 40 5
0 S - - - 0.20 9 SensorBinary Get 9 2 30 2 5
0 S - - - 0.20 9 Alarm Get (v3) 9 5 71 4 0 7 0 5
0 S - - - 0.20 9 SensorMultilevel V5 Get 9 4 31 4 1 0 5
0 S - - - 0.20 9 SensorMultilevel V5 Get 9 4 31 4 3 8 5
0 S - - - 0.20 9 SensorMultilevel V5 Get 9 4 31 4 5 0 5
0 S - - - 0.20 9 SensorMultilevel V5 Get 9 4 31 4 1b 0 5
