Problem with Razberry install
Posted: 06 May 2016 18:41
I have fresh install on Raspberry Pi 3 (with device tree switched off), but the module doesn't work and show in log
What can be wrong? What should I check?
[2016-05-06 17:39:16.634] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-05-06 17:39:16.836] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-05-06 17:39:16.836] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2016-05-06 17:39:16.836] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2016-05-06 17:39:16.836] [C] [zway] Get Serial API Capabilities returned zero.
[2016-05-06 17:39:16.836] [I] [zway] Removing job: Get controller info and supported function classes
[2016-05-06 17:39:16.846] [D] [zway] Worker thread exit point
[2016-05-06 17:39:16.846] [D] [zway] Worker thread successfully finished
[2016-05-06 17:39:16.847] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2016-05-06 17:39:16.864] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
