Antenna signal ?
Posted: 05 Jul 2017 09:09
by vincen
Hi
Having range issue in my flat with my ZWave devices I'd like to know what is best orientation to use for the board to get better coverage ? A radio coverage schema avalaible somewhere ?
Vincèn
Re: Antenna signal ?
Posted: 10 Jul 2017 10:07
by vincen
no one has any clues about it ?? very disappointed with my board and the so short range
Posted: 10 Jul 2017 11:00
RaZberry uses a Silabs reference PCBA antenna for 868 MHz. You can find its diagram in the internet.
But note that final range will depend a lot on the neighbouring of the antenna. Pi case, cables around, etc
Posted: 10 Jul 2017 17:11
by enbemokel
Hi Polto,
so using the Razberry on a Pi and horizontel is the best way?
Or should we use another orinentation with the Pi?
Posted: 10 Jul 2017 23:12
It depends where your devices are and how their antennas are oriented
RaZberry antenna is almost same as WES0031-01-APL868M-01 from
https://www.silabs.com/documents/public ... /AN782.pdf
Check pp 6-11.
