No neighbors & failing nodes
Posted: 22 Apr 2024 21:19
I'm asking for help regarding a problem with "no neighbors" and constantly failing nodes (node disconnected):
Yesterday I tried to setup a new System with a new SD-card (news Raspberry OS with Z-Way). I did not work as intended so I bootet from the old SD-card.
Since then I'm getting alerts every few minutes: Connection lost to node xyz.
Checking the neighbors and the timing info and the route map shows:
- the devices are only talking to the controller
- they are not talking to each other (no neighbors found)
The reorganization is failing with "Neighbours update failed".
I tried to use my backup from 3 days ago, still the same issue.
Any suggestions what I can do to restore my network which usually works like a charm?
Thanks,
regards,
Michael
Thanks,
regards,
Michael
