I just got a somfy RTS bridge and am unable to get it to join the z-wave network. Razberry shows that it joined, but the device itself doesn't so it locks me out of needed menus to bridge the RTS channels.
What debug info do i need to provide?
Edit: I should add, this is the first non zwave plus device i have on my network - not sure if that is the issue or if it's with Razberry.
Thanks,
Greg
Somfy 1811265 Issue
Re: Somfy 1811265 Issue
So i got this working. I had to go into the advanced settings menu and reset the z-wave settings on the RTS bridge itself. Re-adding worked and then adding each blind worked. This is sweet!
Good to hear this works. Thanks for reporting
[moderator]
[moderator]
Greg, this is the US version? There is a newer European version that was Z-Wave Plus qualified in August, but not sure if they plan to make a US version as well. I'm still trying to track down the newer European version to see if it's actually for sale now.
http://products.z-wavealliance.org/products/1913
Where did you manage to buy the EU device?
