Dear all,
I tried to associate the fibaro FGBS321Universal Binary Sensor to z-wave me but the device is not recognized.
Do you maybe had the same issue ? are there any plan to add the module which is very interesting.
Thank you for your help
Fibaro Universal Binary Sensor not supported (FGBS321)
With software 1.4 I have
With software 1.4 I have included the device. The inputs seem to trigger. I have one temperature sensor connected, but it does not show-up under device configuration nor under the expert commands. A "forced reinterview" does not make it visible either. I would have expected a sensorMultilevel
Is this a known issue with Fibaro Universal Sensor?
For some reason this problem
For some reason this problem disappeared after a couple of re-interviews. (As required I did have the temperature sensors attached before including the device to RaZberry)
