Has anyone used zway with a schlage lock? I'm trying to set the pin codes using the REST api. For example, setting the code 1234:
http://192.168.1.169:8083/ZWaveAPI/Run/ ... (0,1234,1)
deleting a code:
http://192.168.1.169:8083/ZWaveAPI/Run/ ... (0,1234,0)
Neither of these commands seem to work. The device returns null, which is what I get from all command class calls which are well formed and the device has the command class. However, the code isn't actually added (or removed) from the lock. I know the pin codes can be set via zwave, because I can do so with a vera.
Is there something obviously wrong with my call that is causing my pin set to fail? I should point out that the lock interview reports as complete on all command classes, so the device should be ready to go. The lock does respond properly to lock and unlock commands.
schlage lock pin code not setting
Re: schlage lock pin code not setting
I don't think there's a user 0. I know there's 2 users on mine and when I do a Get(1) and (2) they both come back as being active. Whereas (3) comes back as not active.
Thanks for the tip. So my friend and I both have this lock. The api call didn't work for my lock no matter what number I place in the first argument (0,1,2,3,etc). It returns 'invalid argument for all numbers other than '0'. For '0' I get the expected null return value, but the code doesn't actually get added to the lock.
However, this did work for my friend, but ONLY for the number 2. So the following call worked for my friend:
http://192.168.1.169:8083/ZWaveAPI/Run/ ... (2,1234,1)
I still don't understand what is happening exactly... but I'll post if I figure it out.
So to double check you have the BE469?
Long shot. Check parameter 16:
http://192.168.1.169:8083/ZWaveAPI/Run/ ... 2].Get(16)
This would be how long your user code is set to (and the number of digits you need to send to set). IDK maybe you have it set for 5 digits or something.
Maybe try to do a get for the user codes you're trying to set as well. (sounds like you might be doing this already)
http://192.168.1.169:8083/ZWaveAPI/Run/ ... 99].Get(1)
Then check if hasCode is true (or false) and if status.value is 1
So these gets return null for me. I should point out that *any* get method I run on a command class like this always returns null.
Afaik that is what they should do. If you send a command you either get en error message, or a null to indicate that specific action was successful. For the results you have to read the status:melchoir55 wrote:So these gets return null for me. I should point out that *any* get method I run on a command class like this always returns null.
http://192.168.1.169:8083/ZWaveAPI/Run/devices[4].DoorLock.data.level.value ? "on" : "off"
Have you tried getting parameter 6 from the Configuration CC? That is a 4 byte bit field telling you which user codes are in use. First byte holds the first 8 slots with the least significant bit being 1 and most significant 8. Second byte the next 8 and so on.
Perhaps you have set some manually at the keypad? The lock seems to assign those more or less arbitrary.
http://192.168.1.169:8083/ZWaveAPI/Run/devices[4].Configuration.data[6].val
