Hi all,
i hope there's somebody who could give me a hint.
I included 2 Devolo Meter Plugs (version 2.0).
Switching on/off works fine, however the meter cannot be accessed hence this interview fails, Even If i force the interview of the meter, i don't have any luck getting the meter in the UI.
In the expert-UI, i'm seeing all values of the plug (even with the failed interview)
How do I get those sensors into the SmartHome UI?
Thanks for helping.
My System: Raspi3 with Razberry (latest SW/FW)
Br
Sascha
Devolo Plug 2.0 - no meter available
Re: Devolo Plug 2.0 - no meter available
Hi all!
Same problem here.
The only difference seems to be that I have a Pi Zero instead of the Raspi3.
Any hint in the meanwhile?!
Thanx
Ibi
Same problem here.
Thanx
Ibi
Hello!
I tried to get help from develo regarding this problem. No way, they do not support rasPi at all
They sent a manual and told me to help my self...
While I do not see the meters on the normal GUI, I have found them in the Expert menu. But as long, as they are not included to the other gui I can use them only to check from time to time everything is ok or not.
Thank you devolo support...
![Sad :(](./images/smilies/icon_e_sad.gif)
I buoyed two of them not fulfilling meter interview.
Any chance to get them working?
