Qubino 3 Phase Smart Meter - read exported energy
Posted: 14 Sep 2022 14:06
I have a Qubino 3 Phase Smart Meter in series with my supply from the grid. I am also having solar panels so I need the read both imported energy (kWh ) and exported energy (kWh) from the meter.
Imported energy is fine: a command like
http://RASP4IP:8083/ZWave.zway/Run/devi ... es[50].Get()
will get the data from the meter (with id=3) and the imported energy can be retrieved using the following
http://RASP4IP:8083/ZWave.zway/Run/devi ... ata[2].val
Reading exported energy is a problem however. A command like
still retrieves the imported energy value.
The tech support at Qubino tells me that I need to send an additional byte following the Get() command to the meter in order to get the exported energy:
Raw command: 32 01 80 00
Description:
0x32 - COMMAND_CLASS_METER
0x01 - METER_GET
0x80 - value change depending which measure you want to retrieve and include the Rate type, Scale and Reserved, for the export kWh is 80, for import kWh is 40 (default)
0x00 - the last value is used for kVar and kVarh
Question: Is there a way to do this using the url string as above - or any other way of doing it ??
Description:
0x01 - METER_GET
