Z-UNO blocked after several hours of operation
schmidmi
Re: Z-UNO blocked after several hours of operation
Post by schmidmi »
I made some investigations during the WE. The problem is caused by using the ZUNO_OLED_I2C library.
If I don't use it, everything is working very well.
In my device I want to display the temperature on a local OLED-display like shown in the ZUNO examples. This works, but a some hours the Z-UNO is blocked.
So I made some changes in my sketch, to reproduce the error. For that, I don't use the DS18B20 but increment a variable in the loop and display that value on the OLED Display. With that the device will block after a few minutes.
I the first step I thought, it may be a memory leak somewhere. But with my my test procedure I saw that there is not a specific amount of cycles when the device stops. So there is something else going wrong. What I saw, is that the blinking of the green LED seems to be interrupted sometimes.. That means it is flickering a little bit from time to time. May be there are concurrent processes running on the device?
Nevertheless here the the sketch I used for testing.
Remark: I didn't test, if the problem will be solved by excluding the device from my HC 2.
// Z-UNO used to connect a Mitsubishi A/C controller to Fibaro HC 2
// It provides the actual temperature and an ON/OFF switch.
// The device can be operated via HC 2 or with a local push button.
// Due to the small amount of ram, it was not possible to implement a connection to
// the A/C controller via IR within this device.
// So the task of sending the 288 Bit IR codes is done by an additional Arduino device.
// The Z-UNO provides an binary output to talk to the Arduino.
// September 2017
// by Michael Schmidt
#include <ZUNO_DS18B20.h>
#include <ZUNO_OLED_I2C.h>
#include <EEPROM.h>
// pin connection ds18b20
#define PIN_DS18B20 11
// Shows the state of the device
#define LED_PIN 13
// Output to control the Arduino
#define ControlPin 6
// Input for the local On/Off button
#define SWITCH_LOCAL 18
// local push button handled with ISR
ZUNO_SETUP_ISR_INT0(int0_handler);
OneWire ow(PIN_DS18B20);
// local Display for temperature an state
OLED oled;
// onewire connection temperature sensors
DS18B20Sensor ds1820(&ow);
byte addr1[8];
int temp = 0;           // here we will store the actual temperature
int lastTemp = 0;           // temperature during the last scan cycle
byte currentLEDValue;   // Last saved LED value
float temperature;
// set up channel
ZUNO_SETUP_CHANNELS(
   ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS,
                          getterTemp),
   ZUNO_SWITCH_BINARY(getSWBin,setSWBIN)
void setup() {
    pinMode(LED_PIN, OUTPUT);
    pinMode(SWITCH_LOCAL,INPUT_PULLUP);
    zunoExtIntMode(ZUNO_EXT_INT0, FALLING);
    pinMode(ControlPin, OUTPUT);
    digitalWrite(ControlPin, LOW);
    oled.begin();
    oled.clrscr();
    // Get the last state before shut down
    EEPROM.get(0,&currentLEDValue,1);
    setSWBIN(currentLEDValue);
    oled.gotoXY(0,5);
    oled.print("Status    : ");
    if (currentLEDValue == 0)
      oled.print("Aus");
    else
      oled.print("Ein");
    oled.gotoXY(0,2);
    oled.print("Temperatur:       *C");
void loop() {
//    ds1820.scanAloneSensor(addr1);
//    // obtaining readings from the sensor ds18b20
//    temperature = ds1820.getTemperature(addr1);
//    // make scaled word value for report
//    temp=int((temperature*100));
     temperature += 0.01;
     temp=int(temperature);
    // send data to channel
    // data will be send in case of a change of value only
    //if (abs(temp - lastTemp) >= 5)
    if (abs(temp - lastTemp) >= 0)
      //zunoSendReport(1);
      lastTemp = temp; // store the actual value for the next compare
      oled.gotoXY(72,2);
      oled.print(temperature);
      zunoSendReport(1);
    delay(10000);
//  delay(60000);
// methode to update the state of the device
void setSWBIN(byte value) {
  // value is a variable, holding a "new value"
  // which came from the controller or other Z-Wave device
  if (value > 0) {               // if greater then zero
    digitalWrite (LED_PIN, HIGH); //turn the LED on (HIGH is the voltage level)
  } else {                         // if equals zero
    digitalWrite(LED_PIN, LOW);   //turn the LED off by making the voltage LOW
  // we'll save our value for the situation, when the controller will ask us about it
  if (currentLEDValue != value)
    currentLEDValue = value;
    // Store the actual state in EEProm
    EEPROM.put(0,&currentLEDValue,1);
    // Update HC 2
    zunoSendReport(2);
    // Update local display
    oled.gotoXY(0,5);
      oled.print("Aus");
    else
      oled.print("Ein");
// Interrupt handler to read the local switch
void int0_handler()
    setSWBIN(255);
  else
    setSWBIN(0);
// Binary value read by HC2
byte getSWBin() {
  return currentLEDValue;
// Temperature read by HC2
word getterTemp() {
    return temp;
petergebruers
Post by petergebruers »
I fully agree with what you are saying. I noticed the faint flickering of the green LED too. I will try to write a minimal sketch that only writes to the oled.
I noticed my Z-Uno crashed, so increasing the loop speed and oled printing has the same effect as your sketch... Keep digging!
petergebruers
I am running this sketch right now, I want to share it so you do not have to run the same test as me. I do not see any flickering. I wonder if it makes a difference if you put zunoSendReport after the oled update... My minimalistic sketch does not have zunoSendReport right now, I'll add it if this test does not crash.
// OLED test by petergebruers, based on DS18B20 sketch
#include <EEPROM.h>
OLED oled;
// set up channel
                         getterTemp),
  ZUNO_SWITCH_BINARY(getSWBin, setSWBIN)
void setup() {
  oled.begin();
  oled.clrscr();
float counter;
void loop() {
  if (counter >= 99) counter = 0;
  else
    counter += 0.99;
  oled.gotoXY(0, 2);
  oled.print("Temperatur: ");
  oled.print(counter);
  oled.print(" C");
  delay(1000);
byte getSWBin() {
  return 0;
void setSWBIN(byte value) {}
word getterTemp() {
  return 0;
schmidmi
Post by schmidmi »
I made some further tests with the sketch.
I saw, that sometimes, when the device is blocked, also the white LED ist switched ON (#define LED_PIN 13).
From my point of view it looks like a problem in the stack.
@petergebruers:
I had the same idea with changing the position of the zunoSendReport(). But it doesn't make any change in the behaviour :cry:
petergebruers
Thanks, your information is helpful. Together we will solve this mistery! ;-)
I think I have made some progress. I reduced the code and now it crashes randomly in less than 1 minute. Tell me what you think...
#include <EEPROM.h>
OLED oled;
// set up channel
                         getterTemp),
void setup() {
  oled.begin();
  oled.clrscr();
float counter;
void loop() {
  else
    counter += 1;
  oled.gotoXY(0, 2);
byte getSWBin() {
  return 0;
word getterTemp() {
  return int(counter);
petergebruers
New observation: if you convert to int, the sketch does not crash. But I only let it run for one minute, the test time is a bit short
oled.print(int(counter));
conversion to long and doing math does not crash it within one minute either:
oled.print(long(counter*1000));
But printing a float with 0 precision crashes it in a few seconds:
oled.print(counter,0);
EDIT: I am going to let it rest for a few hours. I need to think... While I do that, I'll let the oled.print(int(counter)); version run...
schmidmi
Post by schmidmi »
Converting the value to an int may be helpful tp províde a stable sketch. But the output on the display would not be as it should be ;)
petergebruers
I agree... I have been delving in the source code of the Wire, ZUNO_OneWire and ZUNO_OLED_I2C libraries and lst files and it has not become any clearer to me. :? I'll try again later. Maybe it is a stack issue like you said and in that case it might be worth waiting for firmware 2.1.1 because that will improve stack space.
p0lyg0n1
Post by p0lyg0n1 »
Hi )
The main reason is stack. OLED uses Print object as parrent, so for print purposes we have to go really deep in stack and if get an interrupt (Timer/Radio) at this moment it overflows the stack. I try to check this. Looks like it's time to reconstruct Print.cpp... and turn off interrupts when write method of OLED is used.
petergebruers
Thank you for confirming our suspicion. As user schmidmi pointed out, he has "worked around the problem" and this is his topic, but I am still interested in one more thing... As you say, disabling interrupts might fix the issue... I wonder, what is the impact on the operation of the Z-Uno. For instance, will Z-Uno queue radio events? If so... what would be an acceptable period to disable interrupts? Maybe 0.5 seconds? I am thinking out loud: if it takes too long, the controller will not be happy and will start sending retries to the Z-Uno... Am I right?
