Send multiple values at once
Re: Send multiple values at once
Multi channels are not available in the user interface, only by raw commands. I will check for the appropriate code to change this.
It works now, you were right.
Is there a way to avoid the Z-Uno resending it always three times? I always get three times the first sensor, then once the second. My script only sends out values once.
Is this triggered by timeouts?
Thanks for reporting back! That is good news!
I use a Z-sniffer tool to catch radio communications, and sometimes I observe more than 1 transmission per report. But it does not happen a lot, I would say < 1% but I have no firm data. I think it can happen for several reasons. Because I am close to my controllers, I doubt it is radio interference, but noise on the radio channel is a possibility. I think, because I have 100 physical nodes, it is a collision in my case. I wonder, in your case, if your controller is sometimes a bit slower to respond to the first packet. Do you observe such behavior with other nodes too? Is it always 3 times? How much time difference is there between the events?
