Power supply on 5V pin / 3.3V pin
Posted: 31 Aug 2016 23:54
by dom
Can we directly connect a 5V power supply to 5V pin ?
Same question for 3.3V pin (with a 3.3V power supply) ?
In the 5V case how many mA can be used on the 3.3V PIN (in order to supply other 3.3V compoments) ?
Re: Power supply on 5V pin / 3.3V pin
Posted: 01 Sep 2016 02:42
Yes, you can connect power to 5V or 3V3 pins directly
For 5->3.3 DC-DC we use MCP1700. It can source up to 250 mA total
Posted: 20 Sep 2016 16:03
by hatchet
PoltoS wrote:Yes, you can connect power to 5V or 3V3 pins directly
I want to supply Z-Uno with 12V, supplied to pins 1 and 3 (7-18V input / gnd).
The plan is to use Z-Uno's DCDC converter to supply peripheral components (like MAX3232) from 3V3 output. Can I do that?
Are there schematics available from the Z-Uno board (not just pinout)?
Thanks,
Rob
Posted: 22 Sep 2016 19:51
by Quikdav
it's a good news to be able to avoid micro USB as power input
