Create multi channel switch
xibriz
Post by xibriz »
Is it possible to use the Z-Uno to create some sort of a multi channel switch?
Backstory: I use Telldus. Telldus does not support Z-Wave Sence, but has Events. I want to use the Z-Uno as a tripple switch. Switch one triggers one event in Telldus, Swtich two triggers another event and so on.
I have created a test Sketch, but dont get the desired result.
If I create a Sketch with two channels of Switch Binary, I get three Devices in Telldus. The Z-Uno as one Device and Channel1 and Channel2 as seperate devices.
When I turn the devices of channel1 and channel2 on/off in Telldus the right setter functions gets called on the Z-Uno.
But when I change the values that the getter functions are reporting, and then calling zunoSendReport(channel) to notify the controller, only the main Z-Uno device gets turned on in Telldus, and only from Channel 1, not Channel 2.
Ok, I know that there was something about the same type on different channels, so I change channel 2 to be a dimmer. Then both channels update the main Z-Uno device in Telldus, not the respectively channel Device.
So what I am asking i guess.. is my dream impossible? Or does my controller sucks (Telldus)? Or a bit of both?
michap
Re: Create multi channel switch
Post by michap »
Yes, it should work, if I understand the requirement right.
Look at certified sample sketch:
http://z-uno.z-wave.me/examples/Certified10Channels/
Here are 3 switches.
I do not know the Telldus controller - and the Z-Wave software version.
But I think from Z-Uno side it should work.
Michael
xibriz
Post by xibriz »
After extensive testing, I can verify that Z-Way supports what I'm trying to do. Telldus does not.
