[closed] 2.0.5 and 2.0.6. CRC doesn't match
Posted: 22 Nov 2016 22:02
by ronaldsnoeck
I am using Windows 10.
I have installed Arduino IDE 1.6.5 as described.
When I install Z-Uno 2.0.5 or 2.0.6 then the error "CRC doesn't match..." occurs.
Is there a sollution?
Re: 2.0.5 and 2.0.6. CRC doesn't match
Posted: 23 Nov 2016 08:30
by michap
What is your current (installed) version - and what Update URL you are using?
Michael
Posted: 23 Nov 2016 09:37
by A.Harrenberg
I had the same issue... I just de-installed Arduino and made a new, clean installation (with the update-URL
http://z-uno.z-wave.me/files/z-uno/pack ... index.json URL as described
here). Then I was able to install 2.0.6 without that error. It seems that as soon as you try to switch between 2.0.5 and 2.0.6 there is miscalculation of the CRC...
Regards,
Andreas.
Posted: 23 Nov 2016 13:46
by ronaldsnoeck
I switched off the virus scanner.
I un installed all and even deleted all data in "C:\Users\Ronald\AppData\".
I followed
http://z-uno.z-wave.me/install
Still no success.
I have another error see att
Regards,
Ronald
Posted: 23 Nov 2016 14:28
by A.Harrenberg
that is strange, in the current error message the path contains "//" which is probably the cause of the error, but I have no idea wheres this would come from...
I can try it on my laptop to verify that it still works on my end, but I can't do it before tommorrow evening.
Regards,
Andreas.
Posted: 23 Nov 2016 21:38
by ronaldsnoeck
Hi Andreas,
at home I repeated the whole procedure again. Now with the target (zuno) connected.
Now it works.
thanks,
Ronald
