Spikes in ADC values - how to eleminate
michap
Post by michap »
Using the ADC 0..3 in Z-Uno for long period I have got some spikes from time to time.
It can be a problem if the value is going out of the needed range - that's why I have changed the procedure for measure the values.
If you see such "spikes" and want to eleminate it - you can use the statistical "median" method.
Get (as sample) 5 values, sort it and take the middle of them. Spikes will be outsorted.
Here is a sample code for 5 readings - maybe it is useful for somebody ;)
It's easy to modify the code for other needs.
static const byte adc[] = {A0,A1,A2,A3};
vA0 = vADC(0);
vA1 = vADC(1);
vA2 = vADC(2);
vA3 = vADC(3);
word vADC(word adcNum){
// use odd number of readings 5,7,9,....
  word vAD[5];
  for(int n=0; n<5; n++){
    vAD[n]=analogRead(adc[adcNum]);
  return Median(vAD,5);
word Median(word *AS1, byte len) {
  byte m;
  byte n=len;
  word temp=0;
  do {
    m=1;
    for(int p=1;p<len;p++){
      if(AS1[p-1]>AS1[p]){
        temp=AS1[p];
        AS1[p]=AS1[p-1];
        AS1[p-1]=temp;
        m=p;
    n=m;
  } while(n>1);
  n=(int)(len/2);
 return AS1[n];
Michael
