Questions about zunoStartLearn()
Posted: 04 Nov 2017 19:36
1. Is it possible to get whether z-uno is in learning state? I'd like to indicate learning (board red led is not visible as z-uno is inside case).
2. Native indication is not clear - it blinks with red led but looks like it indicates start of learning instead of learning state. If zunoStartLearn(30) is called (should initialize 30 seconds learning according to documentation), red led on the board blinks only for 5 seconds.
3. Inclusion in z-wave network works only if z-uno is able to directly communicate with controller - Fibaro HC2 in my case. If z-uno is far from controller it does use z-wave network members nearby to reach the controller. While other z-wave devices utilize z-wave mesh network for inclusion. Is there a way to make z-uno register without direct connectivity to controller? Maybe I need to configure it somehow?
