modbus rtu and zuno
Vitali
modbus rtu and zuno
Post by Vitali »
Hey. I try to solve the problem by integrating z-wave and modbus RTU (RS-485) last 1-2 months. Does anyone have any experience with this? I'm trying to send a simple command to read or write the register, but it does not work. What I am sending is not recognized correctly. How to send a command to read and write? :( :?:
 if (varState > 0) {
		 sendText = '01030200017984';
	 else {
		 sendText = '0103020000b844';
	 digitalWrite(pin_direction_RX_TX, HIGH);
	 delay(5);
	 Serial.print(sendText, HEX);
	 Serial0.print(sendText, HEX);
	 delay(5);
	 digitalWrite(pin_direction_RX_TX, LOW);
brunoap
Re: modbus rtu and zuno
Post by brunoap »
I'm looking for information about communications between Z-Wave and Modbus, could you get it to work? Would you mind sharing the information?
Thank you very much and best regards, Bruno
Modbus is based on RS485. Check this https://z-uno.z-wave.me/examples/rs-485/
Z-Uno Shield has a built in RS485 hardware.
