compiling error for multiple sensors
Posted: 02 Sep 2020 21:48
I have been trying to get multiple water sensors to run on a Z-Uno. I am new to the Z-Uno so I adapted the water level example below. One sensor works just fine and I can get both sensors to run and return data if I leave out the second ZUNO_SENSOR_MULTILEVEL. When I add this I get the following error:
exit status 2
C:\ Program Files ( x86)\Arduino\arduino-builder returned 2
Error compiling for board Z-Wave>ME Z-Uno
Can somebody give me a clue as to what I am doing wrong?
exit status 2
// demo sketch for connecting multiple level water sensor to Z-Uno
// add library
#include "ZUNO_DHT.h"
// pin connection sensor
#define PIN_SENSOR1 A0
#define PIN_SENSOR2 A1
ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_ALWAYS_AWAKW);
// set up channel
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE,
SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE,
SENSOR_MULTILEVEL_SIZE_ONE_BYTE,
SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
getterLevel1)
getterLevel2)
int level1; // here we will store the data sensor
int level2;
int levelpercent1; // here we will store the value level percent
int levelpercent2;
void setup() {
Serial.begin();
Serial.println("start");
void loop() {
// obtaining readings from the level water sensor1
level1=analogRead(PIN_SENSOR1);
Serial.print("level1 = ");
Serial.println(level1);
// in percent
levelpercent1=level1/10.24;
Serial.print("levelpercent1 = ");
Serial.println(levelpercent1);
// send data to channel
zunoSendReport(1);
// send every 30 second
delay(3000);
// obtaining readings from the level water sensor2
level2=analogRead(PIN_SENSOR2);
Serial.print("level2 = ");
Serial.println(level2);
// in percent
levelpercent2=level2/10.24;
Serial.print("levelpercent2 = ");
Serial.println(levelpercent2);
zunoSendReport(1);
delay(3000);
byte getterLevel1() {
return (byte)levelpercent1;
byte getterLevel2() {
return (byte)levelpercent2;
