New version of RaZberry is released
pz1
Sometimes it helps if you
Post by pz1 »
Sometimes it helps if you first try to Exclude the device, and then push the Re-include device button.
pacaj2am
dlc
Post by pacaj2am »
what was the problem with DLC nad how was IT sloved?
tank tou for updates and development...
lpreschke
Can't include düwi z-wave wall controller anymore
Post by lpreschke »
I had an old razberry installation (installed in march) working.
I installed the current version (1.3.1) on a new sd card. Now I can't include my düwi z-wave wall controller anymore :-(.
The old version inclueded an exlcuded the controllers without any problems. The new version doesn't.
Any hints for me?
Please provide us with the
Please provide us with the log during inclusion
lpreschke
LOG current version (1.3.1) failed inclusion
Post by lpreschke »
[2013-06-13 23:17:14.648] Adding job: Add/re-include node to network
[2013-06-13 23:17:14.657] SENDING (cb 0x02): ( 01 05 00 4A 41 02 F3 )
[2013-06-13 23:17:14.676] RECEIVED ACK
[2013-06-13 23:17:14.689] RECEIVED: ( 01 07 00 4A 02 01 00 00 B1 )
[2013-06-13 23:17:14.698] SENT ACK
[2013-06-13 23:17:14.700] SETDATA controller.data.lastIncludedDevice = Empty
[2013-06-13 23:17:14.701] SETDATA controller.data.lastExcludedDevice = Empty
[2013-06-13 23:17:14.702] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2013-06-13 23:17:14.703] SETDATA controller.data.controllerState = 1 (0x00000001)
[2013-06-13 23:17:33.616] Job 0x4a (Add/re-include node to network): Job not removed before timeout (awaiting for more callbacks?)
[2013-06-13 23:17:33.618] Job 0x4a (Add/re-include node to network): Cancelling
[2013-06-13 23:17:33.619] Job 0x4a (Add/re-include node to network): fail
[2013-06-13 23:17:33.621] Adding job: Add/re-include node to network
[2013-06-13 23:17:33.634] SENDING (cb 0xc5): ( 01 04 00 4A C5 74 )
[2013-06-13 23:17:33.653] RECEIVED ACK
[2013-06-13 23:17:33.655] Removing job: Add/re-include node to network
[2013-06-13 23:17:33.700] RECEIVED: ( 01 07 00 4A 02 06 00 00 B6 )
[2013-06-13 23:17:33.712] SENT ACK
[2013-06-13 23:17:33.714] Job 0x4a (Add/re-include node to network): Done
[2013-06-13 23:17:33.716] SETDATA controller.data.controllerState = 0 (0x00000000)
[2013-06-13 23:17:33.717] Removing job: Add/re-include node to network
[2013-06-13 23:17:52.577] Job 0x4a: deleted from queue
[2013-06-13 23:17:52.613] Job 0x4a: deleted from queue
lpreschke
LOG older version sucessfull inclusion
Post by lpreschke »
[2013-06-13 22:59:04.102] Adding job: Add/re-include node to network
[2013-06-13 22:59:04.107] SENDING: ( 01 05 00 4A C1 5F 2E )
[2013-06-13 22:59:04.127] RECEIVED ACK
[2013-06-13 22:59:04.139] RECEIVED: ( 01 07 00 4A 5F 01 00 00 EC )
[2013-06-13 22:59:04.149] SENT ACK
[2013-06-13 22:59:04.149] SETDATA controller.data.lastIncludedDevice = Empty
[2013-06-13 22:59:04.152] SETDATA controller.data.lastExcludedDevice = Empty
[2013-06-13 22:59:04.153] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2013-06-13 22:59:04.154] SETDATA controller.data.controllerState = 1 (0x00000001)
[2013-06-13 22:59:16.189] RECEIVED: ( 01 07 00 4A 5F 02 00 00 EF )
[2013-06-13 22:59:16.200] SENT ACK
[2013-06-13 22:59:16.202] Job 0x4a (Add/re-include node to network): Node found: #0
[2013-06-13 22:59:16.204] SETDATA controller.data.controllerState = 2 (0x00000002)
[2013-06-13 22:59:16.543] RECEIVED: ( 01 13 00 4A 5F 04 19 0C 01 01 01 72 80 85 EF 20 26 27 85 82 57 )
[2013-06-13 22:59:16.560] SENT ACK
[2013-06-13 22:59:16.561] Job 0x4a (Add/re-include node to network): Adding controller: #25
[2013-06-13 22:59:16.563] SETDATA controller.data.controllerState = 3 (0x00000003)
[2013-06-13 22:59:16.564] SETDATA controller.data.lastIncludedDevice = 25 (0x00000019)
[2013-06-13 22:59:16.565] SETDATA devices.25.data = Empty
[2013-06-13 22:59:16.567] SETDATA devices.25.instances.0.data = Empty
[2013-06-13 22:59:16.569] SETDATA devices.25.instances.0.data.dynamic = Empty
[2013-06-13 22:59:16.570] SETDATA devices.25.instances.0.data.dynamic = False
[2013-06-13 22:59:16.571] SETDATA devices.25.instances.0.data.genericType = Empty
lpreschke
Any news on this?
Post by lpreschke »
Any news on this?
jzapater
I have the same problem :(
Post by jzapater »
We need a solution.
Thanks.
pz1
Roadmap
Post by pz1 »
Can we have an update for the roadmap (http://razberry.zwave.me/roadmap.php)?
There is nothing critical
There is nothing critical about the log. RaZberry just do not see the device to be included. Please try first to exclude it. If it succeed, include it.
