New version of RaZberry is released
pierre2302
INSTALL NEW VERSION
I do not manage to install the version 1.4.1. With the links above
if somebody can help me THANK YOU
pierre2302
Solved error from me
The .Get() should update all
The .Get() should update all supported sensors.
As a matter of fact with v1.4.1rc1 I do not need to perform the .Get() at all. All 6 sensors (2 binary and 4 temp) of the Fibaro US do automatically update the Z-Way tree.
Unfortunately the SwitchBinary status, which used to automatically update the Z-Way tree, does not do so anymore since version 1.4.
Can this SwitchBinary status be fixed so it has the previous behaviour?
Thanks,
Pieter
Thanks,
Pieter
We are not aware about a
We are not aware about a problem with SwitchBinary reports. Please provide us more info. I suppose the problem in on the side of the device, which does not send the report to the controller
We have removed them since
We have removed them since these will not be implemented in Z-Way/RaZberry. At least not as it was before in Z-Cloud. The reason is that these commands are not routed (so it is no all, but all in direct range), so it's usage is very limited and unpredictable.
Way better is to explicetelly specify the list of devices to be turned off
Possible workaround
See this post for something that looks like a work around: http://en.z-wave.me/comment/2571#comment-2571
This is the case in the new
This is the case in the new UI. Please wait a bit
