Bug report (?): ZWaveAPI/Run/ <command> : Wrong cmdClass nbr
Allen912
Post by Allen912 »
Since the beginning, I've got a few dificulty to use direct access like this :
/ZWaveAPI/Run/devices[2].instances[0].commandClasses[0x20].Set(255)
Answer :
Error 500: Internal Server Error
Uncaught TypeError: Cannot call method 'Set' of undefined
In fact, it seems the same problem as here : http://en.z-wave.me/content/documentation-wrong
But his solution doesn't work for me.
While checking and preparing my post here, I found my solution by myself.
By checking my console, It's 0x25 commandClasses which is used !
see below :
xx/ZWaveAPI/Run/devices[5].instances[0].commandClasses[0x25].Set(255)
Indeed, this url works...
Switch: Everspring AN157
Can somebody explain why ?
I also still have my problem with my everspring st814, which failed to complete interview...
Thank you...
pofs
Re: Bug report (?): ZWaveAPI/Run/ <command> : Wrong cmdClass
Post by pofs »
Your device doesn't announce it supports command class Basic (0x20) in NIF, so z-way doesn't allow to access it. On the other hand, SensorBinary (0x25) is supported and you can call Set for it.
Which CCs are failed to complete interview for ST814? You can see it in expert mode.
Allen912
Post by Allen912 »
Thanks for your answer. It's more clear.
Here are the results of the interview:
Edit
It finally worked by forcing part re-interview. But I still have issues listed in my next post...
Allen912
Post by Allen912 »
Here is the strange results displayed in mobile view :
(2) shouldn't be displayed...
The hygro is not displayed in expert Sensors / view..
In Z-Way Home Automation UI View, only bad temperature is displayed...
pofs
Post by pofs »
Which version of Z-Way are you using? Try to update to the latest one.
It is currently either 1.5.0 (stable) or 1.7.0-rc1 (beta).
This is a know bug in Everspring ST814 device. It mizes up humidity and temperature reports, so that only the last made is seen.
See this:
http://wiki.zwaveeurope.com/index.php?t ... ity_Sensor
Allen912
Post by Allen912 »
Thanks.
Those cap's were made with 1.5.0 rc1-1.
I'm going to read your link. I hope there will be a manual correction possible to avoid constructor's bug...
